Metalcloak Thread
Old 03-23-2014, 12:24 PM
  #931
Invest2m4's Avatar
Originally Posted by DallasJKU
I think I will be going with a new DS anyway just in case. No need to cut corners at this point.
When you see everything at full droop, you'll know you need a new DS, haha. I have the 6Paks, so not sure if they have a longer extended length than the ARB, but my stock driveshaft is the limiting factor as it can't clear the exhaust enough to fully droop. I'll be putting a new shaft on during the next few weeks.
Old 03-23-2014, 12:25 PM
  #932
DallasJKU's Avatar
My AEV doesn't have that problem so I figured I should do it right the first time. Are all DS just plug and play??
Old 03-23-2014, 12:28 PM
  #933
K9wells's Avatar
Did you modify the exhaust yet because even with TW 1310 it still limits my DS so now I am Modifying the exhaust.
Old 03-23-2014, 12:29 PM
  #934
DallasJKU's Avatar
Not yet. So many things to research.
Old 03-23-2014, 12:37 PM
  #935
Brightwhite's Avatar
Is anyone running the MC coils with Fox 2.0 shocks? Or the coils with any other shocks other than the 6 paks or OmE's?
I think I am going to go a route with my suspension that builds up over time. Start with 2.5 or 3.5" coils, and fox 2.0 or evolution shocks. Then add control arms and track bars down the road.
Any thoughts?
Old 03-23-2014, 01:19 PM
  #936
jnabird333's Avatar
Any thoughts?
I am running them with Bilstein 5160s. To me, it is a little firm.
Their springs are better paired with a soft shock in my opinion.
FWIW, the OME shocks are soft, good but soft. They also valve the 6 packs soft.
Old 03-23-2014, 01:22 PM
  #937
rodi's Avatar
Can't you just do the exhaust spacer, which will cost you nothing in comparison to DS and go from there?
  #938
DallasJKU's Avatar
I have heard both.
Old 03-23-2014, 01:26 PM
  #939
Invest2m4's Avatar
I hope to avoid messing with the exhaust. The options out there won't play nice with my skid plates.
Old 03-23-2014, 01:28 PM
  #940
K9wells's Avatar
From my understanding is the exhaust spacer allows the driveshaft to clear and the reason for upgrading the driveshaft is do to the CV boots prematurely shredding at full droop.
Quick Reply: Metalcloak Thread
