Metalcloak Thread
#791
Actually, for the rear, the stock arms are not too short with 4.5 springs. AEV designed it that way. Yes it rotates the axle closer to the pinch seam, but it keeps my pinion angle just fine. I have 67000 miles on the stock driveshaft (4 door)). for a 2 door it would not work; reason why AEV doesn't offer it on a 2 door.
#792
Hoping to order the entry 2.5" MC lift kit which includes front upper CA's. I'm considering adding another set of CA's and wondering if the rear upper arms would be the best choice.
#793
If you have a stock driveshaft, you should be fine without the rears. If you have a 2-door also, it may be better with stock arms. I just put the 2.5 game changer on and will be shortening my rear uppers to get more of a stock pinion angle. I have some serious coil bowing.
#794
Any reason why they start with the uppers while it seems every other kit starts with the lowers?
#795
#797
#798
Sent from my Galaxy Note 3 while crawling over mini trucks.
#799
If you are referring to metalcloak and I'm guessing you are (I haven't read up yet to catch up with the convo)... I just read a post the other night from Jeepineer, or Matson, I can't remember which, but I believed they stated they went with the uppers first because the stock lowers had decent flex for what they were and the uppers would give a bigger benefit to start. Don't quote me exact on this as I did a lot of reading that day but I'm nearly 70% sure one of them stated that. There was other stuff stated too but I can't Remember everything. Maybe something about some angle correction or something? Dunno about that part. Sent from my Galaxy Note 3 while crawling over mini trucks.
#800
Yeah, I tried for a couple minutes to find the post so I could post it but, I'm on my cell right now and it was taking more time than I was willing to put into it. if I find it later on my laptop I'll post it up. I'm curious myself now exactly what all it was he stated.
Throwing this out there too, Jeepineer mentioned they recommend a certain order of the build to maximize and get the best flex, performance ...etc. out of it. I don’t personally know what that order is but it probably wouldn't be hard to find out by dropping one of them a mail if one wanted to find out.
