Metalcloak Thread
#783
Looks to me like the axle needs to be pushed back. Is the wheel centered in the wheel well?
If you want to get rid of the bow in the coils cut the coil perches off the axle and rotate them so they are level on top to the tube and weld them back on.
#784
The axle is definitely back far enough. Maybe too far.
#788
Looks like a combo of this and what monte417 said. My pinion angle is about 1 degree from horizontal. I'm still running a stock driveshaft, so the near term solution is to shorten the upper arms. When I go to a new driveshaft, I'll cut and rotate the coil perches. The axle is definitely back far enough. Maybe too far.
#789
sent from my work leash
#790
?? They're adjustable. I asked the question before I checked my pinion angle. That said, 4.5" on stock arms = arms are too short.
