Metalcloak Thread
Old 01-20-2014, 10:48 AM
  #781
Invest2m4's Avatar
Just installed my 2.5" game changer. Does the bend in the rear coils look normal? It's on a 2-door. MC says it's fine...
Old 01-20-2014, 11:51 AM
  #782
4x4chick's Avatar
It look a bit to much for me on a 2,5" lift. Maybe someone ells with the 2,5" lift can compare it to theirs.
Old 01-20-2014, 02:32 PM
  #783
TheDirtman's Avatar
Looks to me like the axle needs to be pushed back. Is the wheel centered in the wheel well?
If you want to get rid of the bow in the coils cut the coil perches off the axle and rotate them so they are level on top to the tube and weld them back on.
Old 01-20-2014, 02:49 PM
  #784
Monte417's Avatar
Originally Posted by Invest2m4
Just installed my 2.5" game changer. Does the bend in the rear coils look normal? It's on a 2-door. MC says it's fine... <img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=525087"/>
Maybe try shortening your upper arms
Old 01-20-2014, 05:23 PM
  #785
Invest2m4's Avatar
Originally Posted by TheDirtman
Looks to me like the axle needs to be pushed back. Is the wheel centered in the wheel well? If you want to get rid of the bow in the coils cut the coil perches off the axle and rotate them so they are level on top to the tube and weld them back on.
Looks like a combo of this and what monte417 said. My pinion angle is about 1 degree from horizontal. I'm still running a stock driveshaft, so the near term solution is to shorten the upper arms. When I go to a new driveshaft, I'll cut and rotate the coil perches.
The axle is definitely back far enough. Maybe too far.
Old 01-20-2014, 05:29 PM
  #786
Monte417's Avatar
Question for guys running metal cloak arms. Do those duroflex joints need to be greased?
Old 01-20-2014, 06:36 PM
  #787
mattgt5's Avatar
No they don't.
sent from my work leash
Old 01-20-2014, 06:50 PM
  #788
BuckLisa's Avatar
Looks like a combo of this and what monte417 said. My pinion angle is about 1 degree from horizontal. I'm still running a stock driveshaft, so the near term solution is to shorten the upper arms. When I go to a new driveshaft, I'll cut and rotate the coil perches. The axle is definitely back far enough. Maybe too far.
Man; I have a 4.5 AEV lift with stock arms in back and my springs are perfectly straight. Somehow I think the Metalcloak arms are set too long?
Old 01-20-2014, 07:00 PM
  #789
mattgt5's Avatar
Your springs are going to be straighter with stock arms. You haven't moved your axle position back. If you lengthen the lowers to push the axle back, clearing larger tires, you have to shorten the uppers to rotate the spring perches back towards the front. Going as far as you can until DS angle is too poor. If that is not enough rotation to straighten your springs , you can always get wedges and retainers to finish it off.
Old 01-20-2014, 07:14 PM
  #790
Invest2m4's Avatar
?? They're adjustable. I asked the question before I checked my pinion angle. That said, 4.5" on stock arms = arms are too short.
Quick Reply: Metalcloak Thread
