Metalcloak Thread
#651
#652
You are not comprehending that the Metal Cloak raised track bar bracket is the problem. Their track bar can only be used with their bracket. I am not sure if you are laughing out loud at your ignorance? But it makes no sense to use, and you do not gain anything by using the metal cloak raised track bar bracket other then the raised roll center.
#654
Who even makes a straight track bar for jks? im currently running the stock bar on there new bracket and my flex is exactly the same, but my axle is off center by about 2" with the stock bar.
#655
I think his was homemade. So are you running 3inch bumps? Then it would be the same put a smaller bump stop and see of it clears the factory exhaust.
#656
Im the one making a homemade one...What happened to your brain? Bumps play a minimal part in this. Factory exhaust might hit, but i dont have one to even test. Your arguing it limits flex and it clearly does not. This ongoing argument is pointless. Your looking to far into the many variables of everyones different builds.
#657
#659
Its not your exhaust is limiting your flex then. I will blame the weaker part. Still as said theres always variables and many ways to approach each.
#660
