Metalcloak Thread
#641
I am sorry but it makes no difference on a 3.5" either. If you run the factory track bar on a 3.5" lift you will still have the same amount of clearance and articulation, your axle would just be offset.
#642
Well this all got started because some people are running a straight rear track bar. Read back it's not about the factory track bar.
#644
If you are running a 3.5" raised track bar on the axle the factory track bar is fine and your axle would be centered.
The metal clock bracket being at 6.5" high causes the clearance issue which is solved by all the bends in the track bar. If they used a 3.5" tall bracket there would be no clearance issues to deal with.
Metal cloak has come up with a $300 solution to the axle centering issue that can be solved with a $35 bracket and a 3" piece of 3/16x3" of bar stock.
#646
#647
So are you saying I could articulate the same amount? I would think it would articulate more to the right than the left but if in general articulation then yes. Lol I'm sorry
#648
You are not comprehending that the Metal Cloak raised track bar bracket is the problem. Their track bar can only be used with their bracket. I am not sure if you are laughing out loud at your ignorance? But it makes no sense to use, and you do not gain anything by using the metal cloak raised track bar bracket other then the raised roll center.
#650
You cannot run MC bracket & A factory trackBar without hitting the factory exhaust wich takes away flex. Clearance is a must.
