Metalcloak Thread
#632
I like the mc video in the link you posted. It shows how well the mc track bar clears the diff and the exhaust. It does exactly what the factory bar does. The video shows it bing used on as factory suspension with factory shocks and factory wheels/tires and the factory bumps. So over the factory bar what benefit are you getting from it besides a higher roll center in the rear? There is no extra suspension travel shown in that video over the factory track bar. You are stating that you are getting more flex due to that track bar but I just don't see it from what you have posted.
#634
Any trackbar bolted in the factory location will clear the factory exhaust. The factory trackbar clears it. With NO bumpstops.
When you run a 6.5" raised bracket, now you run the risk of hitting the factory exhaust without limiting uptravel, or putting a big bend in the trackbar, or running a pre axle dump.
Still none of that means that the MC specific setup gives more travel than any other. all you're doing is regurgitating manipulated advertising.
#635
Sweet jesus we're finally getting somewhere, but the bracket and trackbar don't give you any more flex than stock brackets and stock trackbar.
#637
Any trackbar bolted in the factory location will clear the factory exhaust. The factory trackbar clears it. With NO bumpstops. When you run a 6.5" raised bracket, now you run the risk of hitting the factory exhaust without limiting uptravel, or putting a big bend in the trackbar, or running a pre axle dump. Still none of that means that the MC specific setup gives more travel than any other. all you're doing is regurgitating manipulated advertising.
#638
