Metalcloak Thread
#581
Trust me a zinc plated part will rust hellafast and a yellowzinc coated part (zinc chromate) will rust aswell. It does last way longer, but will still rust. In most areas its not noticable and will be really noticable in salty areas. I know how theyre processed and the coatings are applied. Powdercoat will rust when it scratched or got holes as you said but the coating itself holds up to salt and stuff better. Also water heaters rods are usually aluminum or magnesium on the outer portion if I recall, but thats not at all my expertise. But all coatings will rust when beat on, best way to avoid that part is go aluminum arms. Even stainless is not the best option when salt is eating at stuff.
FWIW: There are some guys I know running uncoated MC arms in southern Ohio (winter salted roads) and they do not show rust (other than where heavily scratched) after two years.
#583
Yeppers It gives you a little time to get the arms touched up without being paranoid about the start of rust. (not much time but more than without.)
#584
Your right, I should of added that the sacrificial part is largely dependent on how thick the plating is. If it is thin it will not take long to get eaten through. Since coating doesn't get eaten it is good as long as it is undamaged.
#585
That isn't good news... I haven't received my kit yet, all my experience with the MC parts is somewhat second hand. Good thing I plan on painting the parts anyway huh
#586
#587
I would. Once you get it let me know how yours looks, I had planned on painting it either way, but i deffinately remember laughing when i saw the coating.
#588
In my kit the arms coating was definitely thicker than the bracket.
#590
