Metalcloak Thread
Old 12-10-2013, 11:29 AM
  #551
aaronstephen's Avatar
Originally Posted by 14Sport
Nope. PSC front brawler mid with brawler bar bumper with 8k winch and psc rockbrawler 2 rear with tire carrier and full-size spare.
Wow. So definitely sits high even with armor. Thanks
Old 12-10-2013, 01:24 PM
  #552
deadmoney's Avatar
I'm about to install the 2.5" dual rate ARB edition. Does anyone know if the upper ca.s will need adjusted, and if so to what specs. The instructions say that they are set for the 3.5".
Also if I'm going to run 35" tires and stock fenders what should my front and rear bump stops be set at. Was going to start with 3" but wasn't sure if that was right or not.
Any other info that one should know before starting the install would also be appreciated. Ha!
Old 12-10-2013, 05:24 PM
  #553
rsbmg's Avatar
On the Metalcloak site it says 35's and stock fenders "Not Recommended" on the bumpstop chart. That said the chart is specific to the gamechanger 3.5 so I would either give them a call/shoot em an email or start at 3 and adjust if needed.
Old 12-10-2013, 05:30 PM
  #554
SF Nick's Avatar
Originally Posted by deadmoney
I'm about to install the 2.5" dual rate ARB edition. Does anyone know if the upper ca.s will need adjusted, and if so to what specs. The instructions say that they are set for the 3.5". Also if I'm going to run 35" tires and stock fenders what should my front and rear bump stops be set at. Was going to start with 3" but wasn't sure if that was right or not. Any other info that one should know before starting the install would also be appreciated. Ha!
I ran the 3.5 MetalCloak lift with stock fenders & 35s with 3inch bump stops. I rubbed pretty hard at full flex. Make sure you cut the rear pinch seam or beat it in with a hammer.
Old 12-10-2013, 05:59 PM
  #555
rsbmg's Avatar
He is in a 2014 so pinch seam is already cut from the factory.
Old 12-10-2013, 06:41 PM
  #556
SF Nick's Avatar
Interesting. I didn't know that......Got any pics of that?
Old 12-10-2013, 06:51 PM
  #557
SF Nick's Avatar
Nevermind found a pic.
Old 12-11-2013, 03:18 PM
  #558
BigMike's Avatar
300lbs of rear bumper and tire. 150lbs of front bumer and winch.
2.5" lift with the above weight added - I netted 3.25" in the front and 2.25" in the back. I only have about 40 miles on the 2.5" springs but the ride feels better than it did with the 3.5" springs. It is less harsh and has better response. I'll report back additional information later.
3.5" Springs
2.5" Springs
Old 12-11-2013, 03:34 PM
  #559
Rob50lx's Avatar
The 2.5" springs look good. I'll be getting my 2.5" tomorrow. I won't be able to install them for a while. I should sit a little lower than you, I've got the hard top going back on, aftermarket skids, PS Rocker knockers, and OR-Fab sport cage.
How are your drive line angles, and caster?
Rob
Sent from my SGH-T999 using Tapatalk 2
Old 12-11-2013, 08:07 PM
  #560
rodi's Avatar
did they start that for 14 or '13 as well?
Quick Reply: Metalcloak Thread
