Metalcloak Thread
#481
Swaybar links installed...
Attachment 514463
Attachment 514464
Final stance with level 8 ZX rick rings installed
Attachment 514465
Attachment 514463
Attachment 514464
Attachment 514465
#483
Mc 3.5
Now it sits perfect. Swapped out the 2.5 for 3.5 springs, did the AFE exhaust reroute and have ordered a new drive shaft.
Thanks to Jay and Brian at Stomper Off-Road.
Next mod is the driver modification. Will wheel this for a bit and see where to go from there.
#485
#486
I've been beating myself up for a month on what lift to get. Coilovers, long arm, game changer...
I'm more leaning towards the full game changer, but I have questions.
1. With bushwackers and 37s, would the 2.5" be enough or should I get the 3.5. (I'm short and want to stay LCG). I know the 37s would fit, but how much articulation would I be giving up?
2. I have a Prorock 44 front and G2/Currie Rockjock 60 rear. Any issues?
3. Can I run front and rear Currie Antirocks? Would this even benefit me?
4. Right now I have a currie rear trackbar to clear my diff. Would the MC one clear?
5. Is there anything else I should buy? I already have 1310 axles.
#487
Level would make it work better when connected, but the Rubicon e disco will not allow for full droop when set this way. Those using manual disconnects could and should set it level.
Sent from my wiz-bang time killing machine
#488
One of your flex pictures, (which doesn't look full flex), shows why it gets set this way. If it started level it would flip thre wrong way.
Edit: My kit came with front adjustibles.
#490
2- shouldn't be any issues
3- you can but the sway bars have little effect on flex (as least with the front disconnected)
4- i don't know, but there is no reason to change it from what you have
5- 1310 is a reference to u-joint size, if it's in the drive shaft it is small for 37s and hard wheeling. If it's in the front axle they should have full circlips and not c-clips.
