Metalcloak Thread
Old 11-27-2013, 05:22 PM
  #411
BigMike's Avatar
Originally Posted by rodi
is that what you did with yours?
Will at MC said it's supposed to be as pictured for the reasons that mattgt5 gave above.
The picture above is way more than 5*. You won't even notice 5* above parallel.
Yes, that is what I did, on this lift and my last 2.5" lift.
Old 11-27-2013, 05:27 PM
  #412
rodi's Avatar
it is precisely 14 degrees.
Old 11-27-2013, 05:46 PM
  #413
mattgt5's Avatar
I should say that my lift was 3.5-4" when my rear links were bent.
Old 11-28-2013, 05:25 AM
  #414
14Sport's Avatar
Starting with step 14, they talk about the MC install.
PowerBlock Magazine
Old 11-28-2013, 05:36 AM
  #415
jnabird333's Avatar
PowerBlock Magazine
If memory serves me correctly... This build did not use a full MC system. Only the arms were used.
Sent from my wiz-bang time killing machine
Old 11-28-2013, 05:53 AM
  #416
BigMike's Avatar
I could be reading some of these posts wrong. But removing the springs and lining up the bump stops at full compression is basically the length of the stock control arms. It seems that aligning the bump stops at normal riding height and then adjusting the pinion/caster angle makes more sense. I have next to no experience setting up control arms though so please correct me if I'm wrong.
Old 11-28-2013, 06:08 AM
  #417
14Sport's Avatar
Hmmm...that makes sense, Mike. I didn't even think about that being stock length. But I would think you want your bumpstops to make contact centered to prevent damage. Aren't the MC bumpstops staggered as you add each puck? If so then it would be different than stock length.
Old 11-28-2013, 06:10 AM
  #418
14Sport's Avatar
It is just the arms. But still helpful I think. Does doing one arm at a time keep the axle centered as they stated?
Old 11-28-2013, 08:29 AM
  #419
Maertz's Avatar
it will get you close, but when the coils are in and the weight is on it the vehicle the lift will push the arms down and in slightly so they need to be slightly lengthened usually for your pinion to be back to where it was, but your correct the bumpstops may not be perfect depending on the height and pinion your running. But shouldnt be an issue. Hell mines stretched just one inch in the front and they still barely hit.
Old 11-28-2013, 08:41 AM
  #420
14Sport's Avatar
Sounds good, Maertz. So as long as they hit I should be good. Got it. One more week to install. I can't wait.
Quick Reply: Metalcloak Thread
