Metalcloak Thread
Old 11-23-2013, 05:05 PM
  #331
Cgflyer's Avatar
Ok so I have one Overland fender (passenger front) installed. Took a little longer than I thought it would and you need to remove the factory rocker guard (Rubicon)...but I got in to go grab a new socket and my check engine light, ABS, Sway bar disco, ESP, brake light and traction control lights are all on and my speedo is at zero. No idea what I could have broken or disconnected just by taking the fender flares off??? Anyone ever run into this?
Old 11-23-2013, 05:16 PM
  #332
Danny4652's Avatar
Originally Posted by n3tfury
Damn, you get 3 1/4" of lift with all that from the 2.5 kit? And to think I was pondering 3.5 with no armor yet :/
Yes, and that is actual lift.
Sent from my iPhone using Tapatalk 2
Old 11-23-2013, 05:25 PM
  #333
Danny4652's Avatar
ID:	512503Click image for larger version
Old 11-23-2013, 05:34 PM
  #334
B 1000's Avatar
That's the 3.5 right? Looks great! Although looks like a slight rake as well. Did you have that rake with your 2.5's too? What wheels/size are those?
Actually I wanted the rake since my JK is an overlander. Once loaded with gear, it will level out.
So here's what's funny about your question. My previous kit actually was a Rock Krawler 3.5 lift. It just sagged to what a 2.5 kit would be. That's why I added the 1.75 spacer in the rear just to even it out. This Metal Cloak 3.5 is definitely a true 3.5 if not slightly over
Wheels are 16" Method Double Standards and tires are Goodyear MTRs in 315/75R16 which measures about 34.5 or so. The MTRs run a lot closer to advertised size than many other tires out there. Also they kick ass
Here are a couple closer shots of the tires and lift...
Old 11-23-2013, 06:41 PM
  #335
mattgt5's Avatar
Check the battery terminal connections. Mine did that once but still drove. It was a loose negative connection.
Old 11-23-2013, 07:09 PM
  #336
Dexter Morgan's Avatar
Originally Posted by B 1000
Yeah I'm kind of amazed how far I had to drop the axle to get the MC coils in. Luckily the MC control arms let the axle drop an insane amount. If I still had stock control arms and brake lines, I probably would have had to remove them.
Yes, I've the stock control arms and had to disconnect the track bar and drop the skid plate to get my 2.5 in coils in! I had to call my Metalcloak rep to make sure he sent the 2.5 and not 3.5 cause I was having trouble dropping the axle enough.
Old 11-23-2013, 08:31 PM
  #337
n3tfury's Avatar
Thanks guys for your pics. VERY helpful!
Old 11-24-2013, 03:50 AM
  #338
BigMike's Avatar
Originally Posted by 14Sport
Any pics or tips would be appreciated as my 2.5" GCL has just shipped. Are you planning on installing the arms and trackbars as set from MC and then adjusting or are you going to try to baseline them for 2.5" pre-install? I know they ship set up for 3.5" lift.
I'm installing the Duroflex kit so yes, all the control arms and front trackbar. I will say that MC could do a better job with their instructions. They basically ship the GC instructions with the Duroflex kit which I find just lazy. They give no measurements for the control arms as a starting point for the 2.5" lift.
I got the front done yesterday and will complete the back today. Then I will set the correct control arm lengths and the pinion and caster angles.
Here is a quick shot from the front completed. HUGE difference.
Old 11-24-2013, 04:57 AM
  #339
n3tfury's Avatar
^Looking great!
Old 11-24-2013, 09:52 AM
  #340
14Sport's Avatar
That looks awesome. Can't wait to get mine. I calculated what I think is a good baseline for the control arms and front track bar based on the information I had. I would be curious to see if the measurements are close to what you end up with.
Control Arms:
UF - 18 3/4
LF - 22 15/16
UR - 18 1/8
LR - 20 1/4
Track Bars:
Front: 32 13/16
Rear: ?
I couldn't calculate that because I don't know the stock length.
I was going to give you these figures if you were going to try to adjust BASELINE before install. That's why I asked. If my numbers are closee would it be possible for you to measure the factory rear track bar?
Thanks. Again it looks great!
Quick Reply: Metalcloak Thread
