Metalcloak Thread
#291
So I finished installing my front Overland fenders on my jk and I must say I was a bit disappointed when I noticed that upon tightening down the fenders, the rear side plate that sits flush to the body and joins with the top plate of the fender has pulled away from the top plate creating a small gap and of course potentially creating a way for rust to get in there. When I looked under the fender I noticed that the rear mounting plate is really only tack welded in place as opposed to fully welded to the top plate which is why this happened obviously. Other than that they are awesome, but for the price I paid for these, I'm kinda disappointed.
#293
#294
I'll post up pics in the morning to show you what I'm talking about, I didn't get any before it got dark. The only thing I might have done wrong was to tighten them too much? But I'm thinking that they should be strong enough to not start pulling apart from over tightening the fasteners. I plan on calling them on Monday to discuss this. I actually had to buy flat black touch up paint to cover the newly exposed steel. I think the remedy would be for Metalcloak to start fully welding the seams on these fenders.
#295
They do fit well , just be careful to tighten slowly and evenly and not to much. Also be real careful drilling out the holes to the 1/2 inch because the sheet metal is so thin that it tears and the bit actually pulls and bends the thin sheet metal up the bit towards the drill And potentially causing distortions and affecting fitment. I used needle nose pliers to pull off little pieces of sheet metal that the drilling created and a file to smooth out the holes.
#297
Wow..... I helped my buddy install Overlines on his JK and aside from it being a big job to do his Metal Cloak turned out perfect. I am sure if you call them they will take care of you... they are a great group of guys fantastic company.
#299
Just got a call about my lift today!!! Said Friday I should see it at my doorsteps. Took just over 3 weeks to get to this point.....it'll be worth the wait I'm sure
#300
