Metalcloak Thread
Old 10-23-2013, 06:03 PM
  #261
Danny4652's Avatar
Originally Posted by aaronstephen
Do you have much added weight in your rig?
Front - RR stubby front bumper with 11500 winch
Rear - no rear bumper, 37" spare with teraflex HD hinge
Armor - PSC body armor and rocker knockers. EVO full skid system.
Sent from my iPhone using Tapatalk 2
Old 10-23-2013, 06:17 PM
  #262
Danny4652's Avatar
Originally Posted by BigMike
Couple of questions.
2014 2D JKR (automatic) will arrive in a few weeks. I was going to go with a RK 2.5 Max Travel but now I'm seriously considering the 2.5 Metal Cloak Duroflex and Bilstein 5100. It just looks like a better product all the way around. I plan on running Goodyear Kevlar 35's on ProComp 17's.
This will be my daily driver and will get wheeled in the N. GA mountains, mainly on trails. It won't be bouncing off any rocks.
Questions:
Front drive shaft - what will I need?
3.6L/Automatic, 4.10 gears, and 35" tires - How will the power be?
What else am I missing?
My complete build list so far:
Metal Cloak 2.5" Duroflex Lift
Bilstein 5100 Shocks
Wheels - ProComp 7069
Gorilla Splined Lug Nuts
Tires - Goodyear MT Kevlar
AEV ProCal
Front Bumper JCR Dagger
Front Bumper Skid - JCR
Rear Bumper w/Tire Carrier ACE
Rock Rails ACE
Flat Fenders Wide*ACE
Synergy Jeep D30/D44 Front Axle Assurance Kit
Tuffy Conceal Carry Drawer
Tuffy Security Console Insert
Tuffy Security Tailgate Enclosure
Spider Web Shade JKini
CB & Antenna
Drake Offroad Fire Ext Mount and Clamps
Trail Cover
Winch - Warn M8000
SPOD
KC Slimlites - Long Range
As others have said you will be very happy with Metalcloak. I've had both RK and MC and there's no comparison (IMO). I've installed 3 RK lifts and two Metalcloaks with similar shock setup sand I think the ride and handling is better with MC (once again IMO).
As for the 35s and 410's you will be fine. I've driven two 2013s with 3.73's and 37s and they were very driveable, nothing like the 3.8.
Nice build list by the way.
Old 10-24-2013, 05:22 AM
  #263
Nibsirb's Avatar
Just ordered the Gamechanger Lite 2.5 ARB edition!!!!!!! I can't wait!!!!!!
Old 10-24-2013, 04:13 PM
  #264
deadmoney's Avatar
I'm torn between the 2.5" ARB edition GC Lite and the ARB Dual-Rate kit!
Just ordered up my 35" Trail Grapplers on the Sidebiter II. So i better get deciding!
Old 10-24-2013, 05:05 PM
  #265
JK_Dave's Avatar
That's good to know. Means I can put that off for a hot minute!
Old 10-24-2013, 05:56 PM
  #266
69mach1's Avatar
Cool
Originally Posted by Lusky
Added Fox 2.0 w/ resi to my 3.5" MC lift.
Attachment 507646
Attachment 507647
Attachment 507648
Correct me if I'm wrong but the pic with the driver side full droop it looks like the shock shaft is bending, which means the shock body is hitting the frame Take a peak with full passenger droop also as that's where I had my problem of the shock body hitting the frame and bending the shock rod, thankfully the Bilstein's shock shafts are cromoly and bend back
Old 10-24-2013, 06:21 PM
  #267
karls's Avatar
Nemesis makes a bracket that bolts on to change the orientation of the bottom shock mount by 90° and it also buys you additional droop, albeit you lose some uptravel.
Sent from my GT-P5113 using Tapatalk 4
Old 10-25-2013, 06:45 AM
  #268
Lusky's Avatar
When my PR 44 arrives I will be moving the bottom shock mount outward x 1 mount width to solve the problem. I don't have a front drive shaft installed right now and test flexed this one time with the new shocks. The shock body is hitting the frame in this pic where the shaft is bending.
Old 10-25-2013, 07:01 AM
  #269
TheDirtman's Avatar
I hope you ordered that pro rock 44 about 3" wider then stock. It will be a much better fit and will give you more room to widen out your brackets. Did you order the tubes naked so you could weld your own brackets on?
  #270
69mach1's Avatar
Cool
I installed the Nemesis front lower shock mounts on mine to fix the problem... till I can swing a set of Metalcloak Sixpack shocks
Quick Reply: Metalcloak Thread
