Metalcloak Thread
Old 12-17-2016, 01:27 PM
  #2581
jadmt's Avatar
Originally Posted by cjnomo
How does one access the nut on the rear passenger upper control arm? The bolt head is clearly and easily accessible, but the nut is covered up by the frame and the gas tank skid. Is the t-bar that hangs down below the frame welded on to the nut?
yes it is a flag nut.
Old 12-17-2016, 02:19 PM
  #2582
cjnomo's Avatar
Thank u sir!!!
Old 12-17-2016, 02:20 PM
  #2583
cjnomo's Avatar
So excited!!!!
Old 12-19-2016, 02:17 PM
  #2584
cjnomo's Avatar
Just finished installing the lift and it's at the alignment shop right now. They claim that they will make the control arm adjustments to dial in castor. I told them to set it at 5 degrees. I took it to Goodyear. Has anyone found that alignment shops torque down control arm bolts while the jeep is on the lift, or are most shops aware that this should be done while the jeep is on the ground? I had about as straightforward an install as I could have expected. I'd hate for the alignment shop to mess up all my hard work. Any thoughts?
Old 12-19-2016, 03:41 PM
  #2585
phljeeper's Avatar
I would assume they will not do it right. Just loosen the bolts up and re torque them when you get home to avoid the joints being bound up.
Old 12-20-2016, 09:05 AM
  #2586
cjnomo's Avatar
Just got it back from the alignment shop. Wow did MC do a fantastic job in the engineering dept!!! Exceeded all my expectations!!! My only concern is that my caster front left vs. front right is off. Should I be concerned? How do the other numbers look?
Old 12-20-2016, 09:15 AM
  #2587
Chuck-The-Ripper's Avatar
Well it looks like they hadn't touched the control arms judging by the castor specs. Not sure how 1/2 turn in on the passenger side lower control arm correlates to degrees but seems like a possibility.
Old 12-20-2016, 09:24 AM
  #2588
jadmt's Avatar
its normal for the sides to be off by that much. It looks like your camber is pretty high tho. at least the driver side camber. should drive nice with the caster at over 5* tho.
Old 12-20-2016, 09:28 AM
  #2589
cjnomo's Avatar
This is what I was thinking. I'll do that and get it remeasured in 500 miles.
I thought camber can't be changed. Does that mean I did some damage to the C's?
Old 12-20-2016, 10:50 AM
  #2590
RhinoHardrock's Avatar
I ordered my Arb 2.5 gamechanger yesterday. Can't wait to check it out and get it installed.
Quick Reply: Metalcloak Thread
