Metalcloak Thread
Old 04-28-2016, 12:10 PM
  #2481
Manu's Avatar
Originally Posted by dcm80401
I have problems with mine.
What problems exactly do you have ??
Old 04-28-2016, 12:17 PM
  #2482
Manu's Avatar
Originally Posted by NJKURPat
What diff cover is everyone running? Any issues with clearance on the MC trackbar? Think SOLID, PSC, blue torch fab, etc...
Also, anyone have experience with ruff stuff tie rods or drag links and clearance with the diff and trackbar?
AEV diff covers front and back with 6 pak 3.5 GC, 35" tires, 2" bumpstops ,rubicon........no problems yet on full flex per this set up with Rubicon sway bar links .
I am thinking of getting the adjustable sway bar links and disconnect completely when doing harder of road stuff.
Old 05-01-2016, 05:52 PM
  #2483
Brianmly's Avatar
So here is my MetalCloak before and after.....tires come tomorrow (Cooper STT Pros 315 17/r17)
ID:	645696   Click image for larger version
Old 05-01-2016, 06:01 PM
  #2484
Brianmly's Avatar
As I was under the jeep today though this is what I found. I'm going to give them a call tomorrow and see what they want to do about it. The lift had been on for the last couple of weeks with just some minor runs. Mainly un-maintained Forrest roads and a couple trails at a ORV.
Overall I am happy with the lift, I just wasn't expecting this.
Gollywomp (01-19-2018)
Old 05-01-2016, 07:52 PM
  #2485
n3tfury's Avatar
Damn that thing was a lowrider before. Especially in the front! Looking good now.
Old 05-01-2016, 07:58 PM
  #2486
Brianmly's Avatar
I think the 90lbs Warn winch may have added to the rake.
Old 05-02-2016, 01:52 AM
  #2487
14Sport's Avatar
Same thing happened to me...twice. Some of the clips aren't seated correctly even thought there look like it. I removed the arm and then used a socket and a dead blow to seat it enough to re-install the snap rings.
Name:	Joint 001 (Medium).jpg
Old 05-02-2016, 05:07 AM
  #2488
kjeeper10's Avatar
As I was under the jeep today though this is what I found. I'm going to give them a call tomorrow and see what they want to do about it. The lift had been on for the last couple of weeks with just some minor runs. Mainly un-maintained Forrest roads and a couple trails at a ORV. Overall I am happy with the lift, I just wasn't expecting this.
Btw this is not common but does happen from time to time, even with JJ's.
Snap it back in and go on your marry way.
Old 05-03-2016, 09:01 PM
  #2489
Brianmly's Avatar
I just "poped" the clip back in with no issues....Looks like it just wasn't seated properly. Just got the new tires yesterday and it's looking a little closer to finished. I took it out for a test drive on one of our local trails and put the flex to a little warm up test.
So far as the drive quality, it's doing great. Just driving down the road it's really just a stock feel until it comes to cornering in which it is so much better. Off road though is a huge improvement that I do notice quite a bit. I decided not to air down for the first little bit on a lousy Forrest road with lots of "wash boarding". It was still rough, but I was able to keep control at a little higher speeds and I wasn't pissing blood by the end. With it aired down in the same road,(only to about 18 psi) it was great. On the rocks and other obstacles it was what you would expect, nice and smooth with the ability to stay in control.
ID:	645962   Click image for larger version
ID:	645963   Click image for larger version
Old 05-04-2016, 03:01 AM
  #2490
kjeeper10's Avatar
I just "poped" the clip back in with no issues....Looks like it just wasn't seated properly. Just got the new tires yesterday and it's looking a little closer to finished. I took it out for a test drive on one of our local trails and put the flex to a little warm up test. So far as the drive quality, it's doing great. Just driving down the road it's really just a stock feel until it comes to cornering in which it is so much better. Off road though is a huge improvement that I do notice quite a bit. I decided not to air down for the first little bit on a lousy Forrest road with lots of "wash boarding". It was still rough, but I was able to keep control at a little higher speeds and I wasn't pissing blood by the end. With it aired down in the same road,(only to about 18 psi) it was great. On the rocks and other obstacles it was what you would expect, nice and smooth with the ability to stay in control.
Looks great man!!
Quick Reply: Metalcloak Thread
