Metalcloak Thread
Old 03-13-2016, 12:14 PM
  #2471
dcm80401's Avatar
Originally Posted by NJKURPat
What diff cover is everyone running? Any issues with clearance on the MC trackbar? Think SOLID, PSC, blue torch fab, etc...
Also, anyone have experience with ruff stuff tie rods or drag links and clearance with the diff and trackbar?
The new style PSC for the diff cover
Old 03-22-2016, 07:21 AM
  #2472
Matt2105's Avatar
Did anyone run their factory shocks with metalcloaks shock relocator brackets that come in the kit? Are the weld-on?
Old 03-22-2016, 07:49 AM
  #2473
Monte417's Avatar
I run those brackets with rancho shocks. They are bolt on and work great
Old 03-22-2016, 07:55 AM
  #2474
Matt2105's Avatar
Excellent to hear. Looks like I'll be spending the $1100.
Old 04-06-2016, 08:07 PM
  #2475
mr.brav90's Avatar
Still looking into the six pack shocks. Anyone regret buying them?
Old 04-09-2016, 04:30 AM
  #2476
hellphenix's Avatar
good call. I'm interested as well
Old 04-10-2016, 08:32 AM
  #2477
dcm80401's Avatar
I have them and I don't regret buying them. However, you are going to need to buy a tank and regulator so that you can charge them from time to time.
Make sure that you can use the up travel or they are a waste of money. If you don't have 3.5" of backspace you will need to install spacers to get the up travel.
I am running 37 (35.5") KO2 with PSC fenders. 2" bumpstop on all 4 corners. 3.5"Gamechanger. MC driveshafts and exhaust spacers.
Hope this helps.
Old 04-10-2016, 09:16 AM
  #2478
jktonka's Avatar
Metal cloak heavy duty tie rod and drag link pretty good? They're a lil cheaper than most others I've looked at and don't require an offset wheel or wheel spacers
Old 04-11-2016, 06:05 AM
  #2479
dcm80401's Avatar
I have problems with mine.
Old 04-11-2016, 06:39 AM
  #2480
mr.brav90's Avatar
Hope this helps.
Helps alot. Those are also the tire I was looking to go to after the duratracs finally wear out (it's gona be a while) what coils are you using.
Quick Reply: Metalcloak Thread
