Metalcloak Thread
Old 10-19-2015, 05:50 PM
  #2391
DECJeep's Avatar
I am looking for feedback from anyone running the overlander suspension on a DD. how does it compare to stock or other aftermarket suspensions?
Any issues? Any additional features you now wish you had gone for?
I like what I have seen, and the ride of the Gamechanger, but don't feel I need to go that far on a DD that sees mostly backwoods trails on the weekends.
Thoughts and advice greatly appreciated.
Old 10-19-2015, 07:13 PM
  #2392
951Rubi's Avatar
Originally Posted by DallasJKU
I know I got about 3.25" from my 2.5"
same here.
Old 10-19-2015, 07:15 PM
  #2393
951Rubi's Avatar
Originally Posted by DECJeep
I am looking for feedback from anyone running the overlander suspension on a DD. how does it compare to stock or other aftermarket suspensions? Any issues? Any additional features you now wish you had gone for? I like what I have seen, and the ride of the Gamechanger, but don't feel I need to go that far on a DD that sees mostly backwoods trails on the weekends. Thoughts and advice greatly appreciated.
not sure what you mean by over lander (don't want to go look it up) but I run their coils and stock arms on my rig.
Does decent, I need CA's and driveshafts though.
Old 10-20-2015, 12:33 PM
  #2394
DECJeep's Avatar
Originally Posted by 951Rubi
not sure what you mean by over lander (don't want to go look it up) but I run their coils and stock arms on my rig. Does decent, I need CA's and driveshafts though. Sent from my iPhone using JK-Forum
Thanks for the feedback! Much appreciated. The Overlander suspension looks like a step down from the GameChanger and the Dual Rate Lift Kits on the website. I have ridden in a friends JK with the GameChanger and it is very impressive on and off road, but I can't justify going that far considering mine is also my DD and I don't do any big rock crawling here. Any feedback on the Overlander system would be greatly appreciated here.
Thanks!
Old 10-20-2015, 01:52 PM
  #2395
POLARIS PRO's Avatar
If you stay around 2.5-3", do you have to buy any other parts (drive shaft, muffler brackets, etc.)?
Old 10-20-2015, 02:24 PM
  #2396
justjeff's Avatar
Default I run the lift
Hello all ,,
I run the Springs arms and Fox shocks. I love it. I believe it rides better than stock. Its a little higher than other 3 1/2 inch lifts ive seen. Maybe it'll settle in later once the winch is on.
Old 10-21-2015, 05:33 AM
  #2397
mr.brav90's Avatar
Another question for those with six pack shocks. Honest opinion of them and what is your sway bar set up. Quick disconnect, anti rock ect. Thanks!
Old 10-21-2015, 08:58 AM
  #2398
PhxSilver's Avatar
I run their 6 Packs and their Springs (I put the 3.5" 4 door springs on my 2 door and got about 4" of lift) I completely DISCO my front sway bar to maximize my travel. If you go with the 6 packs you can really cut down on the bump stops to MAXIMIZE your travel (I use hocky pucks so it is easy to add and remove until you get the perfect amount).
You will have to do some major cutting on the inner wheel liners and wheel flairs but the result is better flex than most coil overs and you spent a lot less money.
Good luck.
Old 10-21-2015, 09:11 AM
  #2399
mr.brav90's Avatar
Good luck.
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=628040"/>
Awesome! Thanks for the reply what did you do with the rear sway bar.
Old 10-21-2015, 08:46 PM
  #2400
DallasJKU's Avatar
I went with exhaust spacers and stock driveshafts. Aftermarket driveshaft is better, but I know many people going many miles with stock DS.
Quick Reply: Metalcloak Thread
