Metalcloak Thread
Old 05-18-2015, 02:42 PM
  #2251
vitodivita's Avatar
Originally Posted by DallasJKU
So far the on road ride of the MC with OME is great. It's definitely much stiffer than stock, but handles all the bumps better than stock or my AEV on my last Sport. It handles crosswinds way better than stock because of the lack of body roll. Head on winds are probably a little worse only because of the added height and the fact that I run flat fenders so it can feel like I'm dragging a parachute sometimes. I can't wait to see its performance off road. Just waiting for the flooding to stop in Texas.
I'm going to say a lot of the stiffness is coming from the OME shocks + large tires. That being said though, this jeep rides fantastic off-road. Extremely comfortable, and feel way more confident with this setup than my old AEV setup.
On road is a little different, I want to blame most of it on the heavy e-rated tires causing excessive bounce to the ride.
Old 05-18-2015, 04:04 PM
  #2252
joseph-98's Avatar
Originally Posted by vitodivita
Looks great!
Where did you get the sticker for the hood? They don't seem to have that on their site. Custom?
Custom sticker
Old 05-18-2015, 04:06 PM
  #2253
joseph-98's Avatar
That looks awful. Sarcasm of course.
Well thank you
Originally Posted by mwtrent
Exact setup I'm going for. Looks great.
Lol yeah i have a friend that did the full over line.... so i went with the over land
Originally Posted by AC/DC
Looks good. Is that the full or mid stinger??
Thats the 24 inch mid ... the bumper is in the pre built bumers... its the 1402 bumper
Old 05-18-2015, 08:13 PM
  #2254
AC/DC's Avatar
Thank you. I have the center bumper just to put the free winch in. I don't know if I want to go with the full or mid stinger.
ID:	611369   Click image for larger version
Old 05-18-2015, 08:26 PM
  #2255
DallasJKU's Avatar
I'm going to say a lot of the stiffness is coming from the OME shocks + large tires. That being said though, this jeep rides fantastic off-road. Extremely comfortable, and feel way more confident with this setup than my old AEV setup. On road is a little different, I want to blame most of it on the heavy e-rated tires causing excessive bounce to the ride.
I'm ok with it being stiffer because it makes it handle much better. On road, it soaks up the bumps with no bump steer or anything. I agree this is heads above my old AEV setup as well. I feel the KO'2's really help with soaking up the crappy roads. I'm excited to test this setup off road.
Old 05-18-2015, 10:21 PM
  #2256
sea bass's Avatar
OME have the least amount of compression dampening - even less than stock from what I can tell by compressing them. . Plus larger tires, if aired down properly should ride softer than stock but maybe them being "E" rated is throwing it off?? What’s the tire pressure? It's most definitely the stiffer spring rate over stock that's giving it the firmer ride. I absolutely agree that this kit improves handling. Not as "mushy" as stock.
Old 05-19-2015, 04:27 AM
  #2257
MotoJeeper's Avatar
E rated tires are definitely going to have a stiffer side wall. I've got Baja MTZs with the OME shocks and it rides fine. Your tire pressure could also be a little high.
Old 05-19-2015, 06:04 AM
  #2258
vitodivita's Avatar
I've settled at 28 PSI. I've run a whole range of PSI up to 38 psi (stupid over inflated) down to 24 psi (mushy, uneasy feeling).
Old 05-19-2015, 01:51 PM
  #2259
AC/DC's Avatar
I run 32 psi in my toyo comp mts. Rides great with the OME shocks. I driven all kind of lifted jeep, the MC springs and OME shocks is one of the best set ups I driven.
Old 05-25-2015, 09:28 PM
  #2260
joseph-98's Avatar
I have bridgestone a/ts and it drives smoother then any other lift i have road on ..
Quick Reply: Metalcloak Thread
