Metalcloak Thread
Old 04-24-2015, 11:38 PM
  #2021
DallasJKU's Avatar
Originally Posted by kraxler
Upgraded my MC 3.5 ARB lift with new tires and wheels. Duratec 315/70r17 and Level 8 Pro wheels..
Looks great!!
Old 04-25-2015, 12:34 AM
  #2022
elitecontrol's Avatar
Originally Posted by vitodivita
Installed the synergy steering and track bar brace over the weekend with no drama with the metal cloak track bar.. Need to flex out the suspension to make sure the track bar doesn't rub.
Metal cloak confirmed with me a few weeks back that their track bar works with that brace so that was enough for me to pull the trigger..
Can you let us know if your coil hits the track bar brace when stuffed
Old 04-25-2015, 02:26 AM
  #2023
14Sport's Avatar
...and if the track bar hits the sector shaft nut when passenger side stuffed along with how much bump you're running. It would also be nice to know the length of your lower control arms, bolt center to bolt center, as that would have an effect on coil positioning.
Old 04-25-2015, 04:49 AM
  #2024
kraxler's Avatar
Originally Posted by NCRUBI2012
Where did you get the pro wheels? I want but thought they were on major delay.
got them at discount tire. Was about three weeks from order to install. There was a quality issue a while back so shipments stopped. I think the are showing up again.
Gollywomp (01-18-2018)
Old 04-25-2015, 05:39 AM
  #2025
bryanwithawhy's Avatar
Installed my 2.5 MC ARB on my 15 Rubi yesterday with some 315 70 17 Duratracs.
-Install was pretty easy, instructions were clear and pictures were helpful.
-Ride is a little rougher than stock, I was hoping for it to be a touch softer but thats ok given the higher center of gravity.
I will see how it wheels and update after that.
Old 04-25-2015, 06:10 AM
  #2026
vitodivita's Avatar
Soon as I get a chance to flex out suspension I'll let you guys know. Currently got 2" of bumpstop up front.
Old 04-25-2015, 06:21 AM
  #2027
sea bass's Avatar
Originally Posted by bryanwithawhy
Installed my 2.5 MC ARB on my 15 Rubi yesterday with some 315 70 17 Duratracs. -Install was pretty easy, instructions were clear and pictures were helpful. -Ride is a little rougher than stock, I was hoping for it to be a touch softer but thats ok given the higher center of gravity. I will see how it wheels and update after that.
How tire pressure you running? Probably wanna be around 28 but chalk test it.
I don't think any lift on the market rides softer than stock.
Old 04-25-2015, 06:43 AM
  #2028
14Sport's Avatar
Great! Appreciate it.
Old 04-25-2015, 07:39 AM
  #2029
DallasJKU's Avatar
How much lift did you get??? Rougher or stiffer?? I haven't heard it rides rough, but it has to be stiffer.
Old 04-25-2015, 09:04 AM
  #2030
Invest2m4's Avatar
Originally Posted by sea bass
How tire pressure you running? Probably wanna be around 28 but chalk test it. I don't think any lift on the market rides softer than stock.
Agree on air pressure. That setup rides soft.
Quick Reply: Metalcloak Thread
