Metalcloak Thread
#1941
I have rubbing issues with my D44 front. Can't run my sector shaft brace because the springs rub against it. My friend has no issues with his D30 front.
Here are some pictures i took last year. http://imgur.com/a/2Otw8
The lower arms are as short as they go and the uppers are set to give me 3.5 degrees of caster.
One thing i noticed, is when i installed my friends MC lift on his JKU, the arms where shorter than mine. That might have something to do with it, perhaps my batch of arms are just a bit too long or they refined their lengths over time.
#1946
#1948
I ran it all last summer and didn't have any issues resulting from the rubbing. But I'm not using the sector shaft brace anymore. I figure that i'll run with the MC arms for this year and switch out to long arms this winter.
#1949
At one point I found this information in this thread but am to lazy to reread the whole thing again, so I will just ask. What is mc springs to actual lift height to advertised lift height. I currently have 35 in tires stock fenders with 4 in terraflex long arms and fox long travel shocks. What I would like to do is move to a true 3 inch with 37s and flat fenders. Eventually get the six pack shock to maximize suspension travel. The shocks now will limit up travel at a lower ride height.
My current springs sit me at a little over 5 inches. Would I be best with a 2.5 and spacer or just get the 3.5. Input greatly appreciated.
Current set up
Current set up
#1950
The 6 packs are going to be a waste if you're keeping the stock flares. Are you currently running a drag link flip? The coils are going to net you slightly more than what they are listed as depending on weight. Your current shocks are more than likely longer extended than a 14" travel 6 pack.
