Metalcloak Thread
Old 11-09-2014, 06:35 PM
  #1851
Voodoo10's Avatar
Originally Posted by Invest2m4
You're not likely rubbing your fenders. More likely the front air dam. Remove it and all should be well.
The air dam is already removed. Its definitely the fenders, I can see where the plastic is worn off/skidded. The rubbing only happens during articulation over rocks, not during turns.
Old 11-09-2014, 06:56 PM
  #1852
D3ADLY's Avatar
You can go either route you mentioned. Or you could even just add more bump stops to stop the tire from raising high enough to contact your fenders.
Cheapest route in order would likely be...
1, Add more bump stops
2, 2.5" lift. Budget boost is all you need
3, MetalCloak fenders, or cut your factory fenders if they aren't already and that's also free.
Old 11-10-2014, 07:19 AM
  #1853
Voodoo10's Avatar
Thanks for the responses guys, much appreciated!
Old 11-17-2014, 05:15 PM
  #1854
genrec's Avatar
Highly interested in the 2.5 Duroflex kit for my 2014 JKU Sport. Question for guys running MC for some time. What exactly is the gold color, a paint, anodizing, powdercoat, or something else, how long does it hold that color for? I'm in SoCal, so I don't have a real harsh climate to contend with, but wondering how stout that gold color is. I also really like the idea behind the duroflex joint especially as a DD, for noise and dampening, can anyone tell me otherwise, why I would not want MC and go with my first choice since doing my homework of RK?
Old 11-17-2014, 05:28 PM
  #1855
Invest2m4's Avatar
It's a zinc coating and it's tough stuff. It's the only product I've had that didn't rust. Even after getting rock rash.
I ran the full Game Changer and prior to that, several other lifts. I'm doing a full custom build now and using the Duroflex joints on my control arms. Still an opinion, so take it for what's worth. It's good stuff.
Old 11-17-2014, 05:48 PM
  #1856
14Sport's Avatar
It has held up in the high humidity, Gulf town world of FL just fine for about a year now. Still looks new. The factory frame paint already looks flat and oxidized, so it's definitely tougher than that.
This is the only lift I have run so can't say how it compares to RC.
Old 11-18-2014, 03:17 PM
  #1857
sjd78's Avatar
Those of you who used jack stands while lifting did you use 6 or 12 ton stands?
Old 11-18-2014, 04:06 PM
  #1858
doubletapdaddy's Avatar
I used 12 Ton stands, partly because I got them at a great price... mostly because I'm paranoid. lol
Old 11-18-2014, 04:07 PM
  #1859
Invest2m4's Avatar
6 tons from harbor freight and I live to tell about it every time
Old 11-18-2014, 04:30 PM
  #1860
sjd78's Avatar
I'm more concerned with the height then the capacity
Quick Reply: Metalcloak Thread
