Metalcloak Thread
Old 11-04-2014, 05:27 PM
  #1831
dalearyous's Avatar
prepared to spend a lot of time on the rear bumper/tire carrier. because the end caps are modular, and the bumper isn't all one piece, there is a bit of play in the mounting process. what will happen is you may find the gate swings too low and scrapes or hits the receiving side. or it is too high and doesn't click and remain closed tightly. it takes some work to get right. remember that the latch should click twice to close. i know that doesn't mean anything right now but you will get it once you have it in your hands and testing the locking mechanism. first time, it wasn't actually locking completely (you will know when it does because the damn thing is rock solid). i was making a turn on a road and my gate flew open. also, when you go to close the gate, the release latch needs to be pushed down. oh, and there is no rear recovery point so make sure you install the tow hitch! i didn't and had to take the whole thing off after getting it right.
for the front bumper install, use MC's sway bar disco relocation kit if you have one. also, move the vacuum pump but use teraflex kit if you plan on using an sPOD. i will say this, their bumpers have some of the best approach and rear angles. i never scrape on things many on the trails do.
i attached some pictures
Originally Posted by K9wells
Awsome how was the install i just ordered the same front bumper and rear tire carrier with bumper. Plus some other things
ID:	582993Click image for larger version
Old 11-04-2014, 08:51 PM
  #1832
K9wells's Avatar
Originally Posted by dalearyous
prepared to spend a lot of time on the rear bumper/tire carrier. because the end caps are modular, and the bumper isn't all one piece, there is a bit of play in the mounting process. what will happen is you may find the gate swings too low and scrapes or hits the receiving side. or it is too high and doesn't click and remain closed tightly. it takes some work to get right. remember that the latch should click twice to close. i know that doesn't mean anything right now but you will get it once you have it in your hands and testing the locking mechanism. first time, it wasn't actually locking completely (you will know when it does because the damn thing is rock solid). i was making a turn on a road and my gate flew open. also, when you go to close the gate, the release latch needs to be pushed down. oh, and there is no rear recovery point so make sure you install the tow hitch! i didn't and had to take the whole thing off after getting it right. for the front bumper install, use MC's sway bar disco relocation kit if you have one. also, move the vacuum pump but use teraflex kit if you plan on using an sPOD. i will say this, their bumpers have some of the best approach and rear angles. i never scrape on things many on the trails do. i attached some pictures <img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=582993"/><img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=582994"/>
Damn that does look nice. I am not running the SPOD but am running the dual ARB compressor under the hood. Also did you have to remove your rear towhook?
SPOD, but am running the duAl
Old 11-05-2014, 04:11 AM
  #1833
dalearyous's Avatar
where is your compressor? passenger or driver side? and do you like it? i really want on board air.
yes you have to remove your rear tow hook. that is why you need the tow hitch and a d ring receiver (i went with smittybuilt). i just picked up the quadratec tow hitch. its cheaper and the nuts are welded onto the tow hitch. no idea how anyone would be able to tighten it down otherwise. also if you are curious my exhaust is the afe 3' hituck RB: https://www.youtube.com/watch?v=od7Ui-TRoF0 ... i highly recommend it too
Old 11-05-2014, 07:45 AM
  #1834
K9wells's Avatar
where is your compressor? passenger or driver side? and do you like it? i really want on board air. yes you have to remove your rear tow hook. that is why you need the tow hitch and a d ring receiver (i went with smittybuilt). i just picked up the quadratec tow hitch. its cheaper and the nuts are welded onto the tow hitch. no idea how anyone would be able to tighten it down otherwise. also if you are curious my exhaust is the afe 3' hituck RB: YouTube Link: https://www.youtube.com/watch?v=od7Ui-TRoF0 ... i highly recommend it too
Alright I will probably pick up a pro link reciever hitch. Here is my setup with the dual ARB it is on the drivers side.
Old 11-05-2014, 05:00 PM
  #1835
kraxler's Avatar
I got me dual ARB compressor mounted there also but I'm thinking of moving it. Got a evap canister relocation kit and am thinking of mounting the compressor on it above the rear axel. Have the MC ARB 3.5 lift. Has anyone tried something like this? Results? Thanks
Old 11-07-2014, 04:36 AM
  #1836
jnabird333's Avatar
Spring Sag Anyone?
I have 12k miles on the 3.5 coils and have lost about 3/4 to 1" (depending on side) of lift on my front coils. This doesn't really bother me because we got WAY more than the advertised to begin with but the rears are still sitting at the original height. The result is pretty excessive rake.
Also, I am not able to stuff my rear fully due to spring rate. I have 2" of bump (all that is needed for my set-up) but have never touched them. I can hang two tires and the rear will not compress to the bumps.
Our miles are with VERY frequent trail riding. This Jeep is a toy, all of these miles are to/from trail rides and/or Jeep events.
Old 11-07-2014, 04:49 AM
  #1837
K9wells's Avatar
Originally Posted by jnabird333
Spring Sag Anyone? I have 12k miles on the 3.5 coils and have lost about 3/4 to 1" (depending on side) of lift on my front coils. This doesn't really bother me because we got WAY more than the advertised to begin with but the rears are still sitting at the original height. The result is pretty excessive rake. Also, I am not able to stuff my rear fully due to spring rate. I have 2" of bump (all that is needed for my set-up) but have never touched them. I can hang two tires and the rear will not compress to the bumps. Our miles are with VERY frequent trail riding. This Jeep is a toy, all of these miles are to/from trail rides and/or Jeep events.
What set up are you running on the front and rear such as bumpers winch tire carrier etc...?
Old 11-07-2014, 04:53 AM
  #1838
jnabird333's Avatar
Poison Spyder Aluminum Fender Flares (Narrow). Poison Spyder Brawler Lite Front Bumper w/ Warn M8000-S Winch, Rear Bumperless w/ EVO D-Ring mounts, Genright Aluminum Tire Carrier. But none of this has changed and all pre existed the MC install.
Old 11-07-2014, 05:10 AM
  #1839
K9wells's Avatar
It may have pre existed before the lift but due to the weight difference not only wil it cause sagging but MC designs their products to be used with full steel armor. If you call Will at metalcloak he is more than helpful with these type of issues . I currently have a rake on mine but its due to no rear bumper nor spare tire. My spare sits where my rer seat is.
Old 11-07-2014, 05:21 AM
  #1840
jnabird333's Avatar
I'm not saying the sag preexisted, I'm saying the bumpers and armor did...
The sag of 3/4-1" is from a measurement taken 1000 miles after lift instal VS two hours ago. The MC springs never removed the stock rake so my nose now looks about 1.5-2" lower than the rear. A heavy front bumper would only make my issue worse. I do intend to call MC but wanted to first see if anyone else had this. In truth, the coils are now close to their advertised lift amount of about 3.75" of lift in the front, the problem is the rear is still much higher at about 4.5" of lift (from stock). Between this and the stock rake that was never removed MY Jeep looks a little silly
Edit to add the front measured 4.75" of lift at the 1000 mile post install measurement.
Quick Reply: Metalcloak Thread
