Metalcloak Thread
Old 10-14-2014, 02:55 PM
  #1791
TRAUMAhead's Avatar
Got my new brake lines installed, first time flexing with Rancho 9000XLs 31/32s and the 2.5" coils, tore the driveshaft boot. Went with 3" bump stops during the install and still got about 2" of clearance with 35s from front fender bracket and the rear fender well. 37s should fit perfect. Already had Nemesis shock brackets on my wishlist due to that pic with the bending shock shaft and stock mounts but even with the shock body on the bottom they still hit the frame.
How long are driveshafts lasting with a torn boot?
Old 10-14-2014, 03:37 PM
  #1792
TheDirtman's Avatar
which boot?
Old 10-14-2014, 04:03 PM
  #1793
TRAUMAhead's Avatar
Originally Posted by TheDirtman
which boot?
Transfer case side, the Rzeppa.
Old 10-14-2014, 04:10 PM
  #1794
TheDirtman's Avatar
Not long as the grease will spin out of the bearings and once they dry up your done.
Old 10-14-2014, 07:50 PM
  #1795
TRAUMAhead's Avatar
Looks like I'm getting a new driveshaft sooner than later.
Old 10-16-2014, 03:19 PM
  #1796
sjd78's Avatar
Are any of you guys running an exhaust spacer kit or aftermarket Y pipe with the 3.5" GC ARB or is an aftermarket front driveshaft sufficient?
Old 10-16-2014, 03:46 PM
  #1797
meep97's Avatar
IIRC this subject was discussed within the last 10(?) pages on this thread.
Old 10-16-2014, 04:12 PM
  #1798
nthinuf's Avatar
Some people have reported moderate luck with keeping it greased. A few have mentioned packing grease in with their fingers while manipulating the joint. But to me, it seems like a huge mess, with layer after layer after layer of grease slinging up to the undercarriage. Better off just going ahead and replacing.
Old 10-16-2014, 04:21 PM
  #1799
mattgt5's Avatar
Look up Carolina driveline. They custom build shafts with all USA parts to your specs. $350 each. Great shafts.
sent from my work leash
Old 10-16-2014, 06:02 PM
  #1800
pjmjk's Avatar
Originally Posted by mattgt5
Look up Carolina driveline. They custom build shafts with all USA parts to your specs. $350 each. Great shafts. sent from my work leash
That seems like a great price. Any pictures of some finished shafts?
Quick Reply: Metalcloak Thread
