Metalcloak Thread
Old 10-08-2014, 06:56 AM
  #1771
Ncb
Ncb's Avatar
Plus if you flip the DL you need 3" of bump stop.
Old 10-08-2014, 07:10 AM
  #1772
jnabird333's Avatar
Not for all flip kits... The synergy kit and d-link will clear will 2". (Well 2.25 of you are using the MC bumps as they have a .25 cap.)
Old 10-08-2014, 12:44 PM
  #1773
K9wells's Avatar
Definitely not flipping it than. Right now I can clear 35s with only one bumpstop.
Old 10-08-2014, 04:34 PM
  #1774
Ncb
Ncb's Avatar
The instructions from Synergy state 3" minimum.
Old 10-08-2014, 05:53 PM
  #1775
Jade_Monkey07's Avatar
Its the trakbar brace that requires the bumps. I used the rough country one that isn't as tall so I get away with 2. Maybe less, I havnt played around with it much
Stay muddy my friends
Old 10-08-2014, 07:36 PM
  #1776
TRAUMAhead's Avatar
If the Synergy track bar bracket clears with 2" bump stops, I don't see why any other mount that raises the roll center by 3" wouldn't work as well. I'm running the Artec mount and Synergy drag link flip. I need to flex it and see if I can get away with 2" bump stops, running 3" right now. Been thinking of getting the frame notched if not.
Anybody running non 6pak 12" travel shocks with either the 2.5" or 3.5" coils?
Old 10-09-2014, 03:56 PM
  #1777
jdenney's Avatar
I have some questions with my quick disconnects.
How do you make it clear the tie rod? And other one, which I don't know the name of?
Old 10-09-2014, 04:13 PM
  #1778
D3ADLY's Avatar
You have to disconnect both sides. Then grab the sway bar itself that they're attached to (the black bar) and roll it up towards the hood of the jeep. It will raise your links so they can clear the other bars you're referring to. (Drag link and tie rod are the names of them.) If I'm not mistaken out should easily clear the tie rod though. Drag link is the one it catches on.
Old 10-09-2014, 04:15 PM
  #1779
jdenney's Avatar
Yea I looked through some threads and was like doh.
Thank you for the reply. They are so hard to get off the bolts, I think I need to size them the same distance
Old 10-09-2014, 04:17 PM
  #1780
D3ADLY's Avatar
Yeah. Just tap them off with something you keep available. I use any random thing I have on me usually.
Quick Reply: Metalcloak Thread
