Metalcloak Thread
#1681
I installed the 2.5 ARB Dual Rate plus the adj Upper Rear Control Arms on my 2 dr JKR this weekend. The directions leave a lot to be desired in my opinion especially as it relates to setting up the control arms. My front uppers are set too long at the moment so my caster is off. That will get changed this weekend.
After struggling through the front suspension on Saturday, I found this website Project-JK.com - Jeep JK Wrangler Resource » TeraFlex Jeep JK Wrangler 4″ Flex Arm Lift Installation Write-Up. The rear went so much better because of it.
Also, there was no mention of what to do with the front brake lines. Had to google that as well to see people routing behind the shocks. But, overall I like the quality of the parts. Can't wait to fix my caster as the steering is quite flighty at the moment.
My wife and I installed the MC 2.5 G-C ARB on our '14 JKUR this weekend along with Nemesis Front Shock Relocation brackets. This is my first jeep and first lift. I found the directions to be more than adequate.
EDIT: Of course I had already done lots of research on the web prior to the purchase and install.
#1682
He didn't know much about setting up a Jeep. Not his fault. Mine.
I should have committed more of the installation process to memory. But, I still believe the directions could be greatly improved especially when they don't even print them.
#1683
3.5" Game Changer ARB
Lift is on and tested. So far so good. Instructions need updated, but was a fairly easy install. A few things that could have went better. No instructions included, Missing hardware, No mention of replacing front brake lines or routing behind shocks , Rear bump stops are not what is pictured or talked about in instructions, Controll arms that were claimed to be preset for 3.5' were not set or even the same side to side.
Once lift was on and alignment done it was time to test. This lift gave me 4.5". the ride is pretty rough but the handling is awesome. Wash boards will rattle your fillings out. The flex is great, and overall im very pleased. [ATTACH=CONFIG]574321[/ATTACH]
#1684
Once lift was on and alignment done it was time to test. This lift gave me 4.5". the ride is pretty rough but the handling is awesome. Wash boards will rattle your fillings out. The flex is great, and overall im very pleased. [Attachment 574321ATTACH=CONFIG]574321[/ATTACH]
#1685
#1686
#1687
#1688
Been reading the Nitrocharger Sport are both stiff and soft so I've been on the fence about them. I know the original Nitrocharger non-sport models with the yellow shaft guards were soft but they're discontinued IIRC. Probably going to give Rancho 9000XL a go with my 2.5" MC coils for the adjustability and can't beat the Shocktober sale.
Here' a thread on the Sport model. http://www.jeepforum.com/forum/f9/ol...views-1183383/
#1689
Compared to stock 2014 JKUR ride, my 2.5 G-C ARB is soft as hell. In fact I wish that is was firmer.
EDIT: I may be crazy though... IDK.
#1690
