Metalcloak Thread
#1662
love the setup and love the ride of the 3.5" GC ARB. i also love my MC front bumper. the MC rear bumper/tire carrier has been a royal pain to dial in the perfect alignment so the tailgate opens and closes as smoothly as they show it does. it seems when i get it to open and close perfectly the latch doesn't lock all the way. when i make my adjustments and get the latch just right i found the bottom of the gate scraping the bottom of the plate below the latch. i'll get it eventually.
front stance
front shot
winch guard on
rear
for some stupid reason, the shop mounted the tire not on the plate. one of the first things i corrected. i then added the tow hitch and a d-ring for the rear:
tow
MC bumper in parts (i have re-assembled it twice)
MC rear parts
front stance
front shot
winch guard on
rear
tow
MC rear parts
#1663
front stance
front shot
winch guard on
rear
tow
MC rear parts
front stance
front shot
winch guard on
rear
tow
MC rear parts
#1664
Too funny, I was about to contact mc about this same issue. The tire carrier has been a pain to get dialed in for me as well. Let me know what you found to work the best. I went on the trail last week and when I got to my campsite I had to use a screwdriver to pry open the gate.
#1665
You probably put the bearing races in the wrong way. I put them in upside down the first time and the arm had a lot of play in it. The second time I got new bearings and put the outer bearing (the bigger one) in the hole first and slid the inside race in while I was mounting the arm on the bumper. It works fine now. I think the latch takes a while to break in too.
#1666
yeah my bearings are right. the gate is rock solid in movement and locking open. when i swing mine shut the bottom scrapes on the bottom plate on the actual bumper. if i swing it hard it locks very solidly. opening it just requires a light yank. i settled with this because it was more important to have it lock closed securely. i still like the bumper and carrier, but i think making the end caps modular, there is a bit of play in bolting the bumper and carrier on.
#1667
#1668
yeah taking the bolt and sleeve out of the carrier hinge was a royal pain too. breaker bar and a lot of hammering to get the sleeve loose. not looking forward to doing it again to adjust the caps. makes me wish i had an air drill. can you run one off the ARB onboard air?
#1669
