Metalcloak Thread
Old 08-06-2014, 06:33 AM
  #1661
4x4chick's Avatar
^^^^^ Yep, that is how and where you measure the lift hight.
Old 08-25-2014, 04:49 AM
  #1662
dalearyous's Avatar
love the setup and love the ride of the 3.5" GC ARB. i also love my MC front bumper. the MC rear bumper/tire carrier has been a royal pain to dial in the perfect alignment so the tailgate opens and closes as smoothly as they show it does. it seems when i get it to open and close perfectly the latch doesn't lock all the way. when i make my adjustments and get the latch just right i found the bottom of the gate scraping the bottom of the plate below the latch. i'll get it eventually.
front stance
front shot
winch guard on
rear
for some stupid reason, the shop mounted the tire not on the plate. one of the first things i corrected. i then added the tow hitch and a d-ring for the rear:
tow
MC bumper in parts (i have re-assembled it twice)
MC rear parts
Old 08-25-2014, 01:29 PM
  #1663
sgregg108's Avatar
front stance
front shot
winch guard on
rear
tow
MC rear parts
Too funny, I was about to contact mc about this same issue. The tire carrier has been a pain to get dialed in for me as well. Let me know what you found to work the best. I went on the trail last week and when I got to my campsite I had to use a screwdriver to pry open the gate.
Old 08-25-2014, 03:24 PM
  #1664
MotoJeeper's Avatar
You probably put the bearing races in the wrong way. I put them in upside down the first time and the arm had a lot of play in it. The second time I got new bearings and put the outer bearing (the bigger one) in the hole first and slid the inside race in while I was mounting the arm on the bumper. It works fine now. I think the latch takes a while to break in too.
Old 08-25-2014, 10:56 PM
  #1665
sgregg108's Avatar
I think I installed the bearings right, I put the outer race in first then the inner race as I installed the arm. I didn't think they would fit a different way the arm itself is solid and doesn't have any play. I've been having issues with the latch. But since I sprayed it w/some silicone it seems to be easier to open. Still think my gf will have a hard time w/ opening it.
Old 08-26-2014, 09:35 AM
  #1666
dalearyous's Avatar
yeah my bearings are right. the gate is rock solid in movement and locking open. when i swing mine shut the bottom scrapes on the bottom plate on the actual bumper. if i swing it hard it locks very solidly. opening it just requires a light yank. i settled with this because it was more important to have it lock closed securely. i still like the bumper and carrier, but i think making the end caps modular, there is a bit of play in bolting the bumper and carrier on.
Old 08-26-2014, 12:17 PM
  #1667
sgregg108's Avatar
Yep, I had the same issue, just adjust the bumper cap hex bolts, need to jiggle it around to make it fit just right.
Old 08-26-2014, 05:40 PM
  #1668
dalearyous's Avatar
yeah taking the bolt and sleeve out of the carrier hinge was a royal pain too. breaker bar and a lot of hammering to get the sleeve loose. not looking forward to doing it again to adjust the caps. makes me wish i had an air drill. can you run one off the ARB onboard air?
Old 08-26-2014, 09:02 PM
  #1669
sgregg108's Avatar
I'm not sure about the arb air and tools. I meant adjusting the left side cap Allen head bolts, I loosened up all of those wiggled it around and it all lined up a bit better
Old 08-27-2014, 10:43 AM
  #1670
dalearyous's Avatar
oh ok, i will give that a shot too.
Quick Reply: Metalcloak Thread
