Metalcloak Thread
Old 06-17-2014, 05:53 AM
  #1521
snags922's Avatar
Hey, does anyone have the MC QDs on the front? They are on there tight. I tried disconnecting them last night to install the brackets and man...never got them disconnected. Do you have to smack them with a mallet to get them off and put them back on? Cause they aren't coming off by any other means.
Old 06-17-2014, 06:08 AM
  #1522
Invest2m4's Avatar
Are you on level ground? One usually has less tension on it and will come off easier. However, nothing wrong giving them a few taps with a hammer. I've used mine a lot and they slide fairly easily now.
Start wheeling more and break them in!
Old 06-17-2014, 06:22 AM
  #1523
snags922's Avatar
It's fairly level ground. They were just installed and have zero hours of off-road on them. That's what I was hoping - once they get broken in, they will be easier to work with. I will take a mallet to them and get them off. Thanks.
Old 06-17-2014, 08:12 AM
  #1524
afletche's Avatar
i just use a rubber mallet to get them on/off. and sometimes need to have someone rock the jeep if it's not level.
Old 06-17-2014, 08:18 AM
  #1525
TheDirtman's Avatar
If they are that hard to get off on level ground you likely need to adjust one of them as they should slide right off if on level ground with no load on them.
Old 06-17-2014, 08:47 AM
  #1526
snags922's Avatar
Rocking the Jeep might help. Thanks.
Old 06-17-2014, 08:49 AM
  #1527
snags922's Avatar
I will have to check that. On the 2.5" lift, i made them as short as I could but I might have one a little shorter than the other.
Old 06-17-2014, 08:58 AM
  #1528
snags922's Avatar
WOW......I just thought of something. Since I have a Rubicon with electronic sway bar disconnect, I could activate that to release any pressure on the sway bar to make it easier to disconnect and reconnect the QDs.
I know many people are asking why did I get the QD sway bar links when I have the electronic sway bar disconnect. It's because I like to have the option, when on some of the more extreme trails, to be able to manually disconnect the sway bar.
Old 06-17-2014, 09:05 AM
  #1529
Jade_Monkey07's Avatar
My old zone ones are basically the same build and they were akways hard even 2 years later. My MC are stiff to get on and off too. Been out 5 or so times and just as stiff. It not uneven ground its the rubber on metal (possibly caked in road grime) that make it tough. I use a screw driver against the spring perch to gently pry them off. Also experimenting with dry graphite lube right now
Stay muddy my friends
Old 06-17-2014, 09:08 AM
  #1530
snags922's Avatar
When I get them off, I was thinking of Frog Lubing the rubber and the metal stud. Frog Lube works great on my guns - should work well on this too.
Quick Reply: Metalcloak Thread
