Metalcloak Thread
Old 06-15-2014, 10:57 AM
  #1471
Invest2m4's Avatar
Originally Posted by 14Sport
Wow that's good to know. So if I ever decide to go with 3.5", all I would need to buy is the coils. No wonder the 2 kits are the same price. I assumed I would need shocks too. I think everything else is the same.
And now you're on to something! They are, in fact, identical except for coils. The only difference is how it sits in the driveway or going down the road (1" taller). You don't gain clearance, flex, or anything. You do get worse geometry and driveline angles though Best part is a higher center of gravity. Rolling a Jeep is even cooler than flipping the sway bar.
Old 06-15-2014, 11:01 AM
  #1472
snags922's Avatar
You make lifts sound so exciting...LOL!
Old 06-15-2014, 11:05 AM
  #1473
snags922's Avatar
But seriously...discussions like this help my understanding of suspensions a whole bunch. Thanks.
Old 06-15-2014, 11:06 AM
  #1474
14Sport's Avatar
lol. Which is why I went with 2.5 in the first place.
Old 06-15-2014, 11:08 AM
  #1475
snags922's Avatar
Same here.
Old 06-15-2014, 12:30 PM
  #1476
kjeeper10's Avatar
Default Metalcloak Thread
Originally Posted by TheDirtman
position of the links has absolutly nothing to do with steering feel or handeling of the jeep.
I knew it was coming.
There's was a change driving over uneven road or hitting a dip. Hard to explain.
2007 Rubicon /2 door/6 speed
Old 06-15-2014, 01:49 PM
  #1477
Monster696's Avatar
Finally got my lift installed.
Suppose to be 2.5 arb edition but it looks pretty high. Going to confirm they sent me the right lift kit. They already messed up with the brake line kit twice.
Here are the before and after. Stock rubicon tires
BEFORE:
AFTER:
Old 06-15-2014, 02:05 PM
  #1478
Invest2m4's Avatar
Originally Posted by Monster696
Finally got my lift installed. Suppose to be 2.5 arb edition but it looks pretty high. Going to confirm they sent me the right lift kit. They already messed up with the brake line kit twice. Here are the before and after. Stock rubicon tires BEFORE: <img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=559868"/> AFTER: <img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=559869"/>
You look really low prior, so it's not a good comparison. Use the stock measurements to determine lift.
Old 06-15-2014, 03:43 PM
  #1479
14Sport's Avatar
I got 3.5" in the front and 3.25" in the rear with the heavier spare. But I started out with 14/56 springs. That has an impact on the overall height difference.
Old 06-15-2014, 04:07 PM
  #1480
BigMike's Avatar
Originally Posted by BigMike
There was on my '09 but not on my '14. The tab is usually at about 12:00 which is where I initially set the end of the coil.
The spring was a sumbitch to turn even with the driver's side jacked up and the axle drooping.
UPDATE:
The passenger side tab is at 12:00 in the front and at 6:00 in the back on the driver's side. The passenger side was correct and the driver's side was correct after I spun the spring 180 degrees to stop it from rubbing on the frame. All is good.
Quick Reply: Metalcloak Thread
