Metalcloak Thread
#1411
#1412
I thought the bolt might be grazing too but no signs of contact.
Plus guys, these are clanking over tiny expansion joints and the like
Sent from my LG-LS980 using JK-Forum
#1413
#1414
Just a thought...
#1415
He needs to check and ensure all the joint snap rings are in place. I had a few not seated correctly from MC. Another member here had the same issue which is what prompted me to check mine at install. I believe he heard a "clanking" which was the ring flopping around.
Just a thought...
Excellent ideas though guys.
All these things to check and it still seems it's a coil issue.
All I really did was replace existing 3.5" RC coils with 3.5" MC coils.
So nothing REALLY changed at all but the common denominator here
#1417
Other things to check...
Check rear track bar bolt to see if it's hitting coil.
What if any C-Gussets? I have a combination of EVO and RK. My coils touch the gusset but they go not make noise.
Check each coil for wear. If they are hitting something it won't take ling to wear through the coating/paint that they are covered in. (smoking gun)
If any of this has been previously mentioned I apologize for the redundancy.
#1418
Just makes no sense other than the coils.
I suspect the part of the coils that are touching each other at the top have a tiny space between that clanks together when slightly more compressed?
#1419
Yes sir...pulled the coils yesterday to triple check them....looked perfectly centered. Just makes no sense other than the coils. I suspect the part of the coils that are touching each other at the top have a tiny space between that clanks together when slightly more compressed? Sent from my LG-LS980 using JK-Forum
#1420
What shocks are you running? I have had a blown shock rattle....
