Metalcloak Thread
Old 05-29-2014, 10:49 AM
  #1321
Jade_Monkey07's Avatar
I was told by metal cloak over the phone to just use brake cleaner to get the dirt off and paint directly over it. I did at least 5 coats on everything(if not 7 or 8). It held up very well on the arms and trackbars and rear bracket. The swaybar links were just too smooth and it scratches of very easily. Im happy still, not a fan of the gold and I wanted the extra protection up here in rusty ol Canada. Its a much bigger job then I anticipated. Took 2 days. I went through 4 cans of rustoleum rust paint. We will see how well it all holds up over time. One wheeling trip down with no damage and more to come.
I dont always drive where others cant. but when I do, its in my Jeep. Stay muddy my friends
Old 05-29-2014, 11:08 AM
  #1322
OC-JK's Avatar
Ordered a metalcloak bushing retrofit kit for my teraflex arms.
Old 06-03-2014, 03:24 AM
  #1323
snags922's Avatar
I will be doing my 2.5" GC ARB install this weekend if the weather holds out (need to do it outside). Anyway, I decided to go with the limiting strap as opposed to exhaust spacer or aftermarket driveshaft (for now anyway). Is there a certain length limiting strap that fits all JKs (mine is a 2012 JKUR if that matters) with an MC lift? Or do I have to wait til my lift is installed and measure? Where does the strap bolt up?
Old 06-03-2014, 03:44 AM
  #1324
Rebar-7's Avatar
You need to have your new lift installed, then cycle suspension and measure. The shop I go to said after measuring go one inch shorter to allow for stretch ? Thinking..
Old 06-03-2014, 06:08 AM
  #1325
TheDirtman's Avatar
Thats correct, you want to allow for stretch. Depending on the length of the strap you may need more or less length. For the differential strap you will likely only need to be about 1/2" shorter. An adjustable clevis mount works good to dial in the correct length.
Old 06-03-2014, 06:25 AM
  #1326
snags922's Avatar
So where does it bolt to?
Old 06-03-2014, 06:28 AM
  #1327
TheDirtman's Avatar
You could use the control arm mount on top of the differential if you want and install the clevis on the frame above.
Old 06-03-2014, 06:42 AM
  #1328
snags922's Avatar
I'm sorry but I'm a little confused. If you use the control arm mount, isn't that moving the limiting strap outward away from the center-line of the vehicle? I thought I would put 1 limiting strap in the center of the axle so it wouldn't hinder any of the articulation that the MC lift gives me. I'm not questioning you by no means. Just trying to understand what I need to do.
Old 06-03-2014, 06:45 AM
  #1329
TheDirtman's Avatar
IF you want to max out articulation while protecting the driveshaft you install the limit strap at the driveshaft which is the center of the differential. You can however mount it whereever you want and welding a double sheer tab in the center of the axle to bolt it will work fine.
Old 06-03-2014, 06:56 AM
  #1330
snags922's Avatar
That is exactly how I pictured it working. Is there any problem with doing it that way?
Quick Reply: Metalcloak Thread
