Metalcloak Thread
Old 05-27-2014, 08:30 AM
  #1301
Invest2m4's Avatar
I do two arms at a time. Otherwise, it's a pain to bolt them up as one arm is longer. Put a GC ARB on my dad's jeep this weekend and had no issues. Track bars i do last and on flat ground.
Old 05-27-2014, 08:39 AM
  #1302
n3tfury's Avatar
Lift
That came out nice. Which fenders are those?
Old 05-27-2014, 08:42 AM
  #1303
Bypass's Avatar
Having a lift is another story.
I do two arms at a time. Otherwise, it's a pain to bolt them up as one arm is longer. Put a GC ARB on my dad's jeep this weekend and had no issues. Track bars i do last and on flat ground. <img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=555902"/> <img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=555903"/> <img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=555904"/>
Old 05-27-2014, 08:44 AM
  #1304
n3tfury's Avatar
Maybe the rear you need to be on the ground, but I was able to do front uppers and lowers while on jack stands with no issues. I did have to get on all 4 tires for the trackbar though.
Old 05-27-2014, 08:46 AM
  #1305
Invest2m4's Avatar
Originally Posted by n3tfury
Lift
Yeah, the lift makes things a lot easier They are the Poison Spyder standard width. We put those on after the lift. Busy weekend: GC lift, PSC fenders, PSC diff covers, Adam's driveshaft, mounted and installed 5 Nitto's on 5 ATX Slabs. Also found time yesterday to put the extended brake lines on the rear (I don't use the front as it's not worth the spongy brake pedal risk and because the stock are plenty long).
Brawler II rear bumper is next weekend, along with sleeves and gussets. Getting there!
Old 05-27-2014, 08:49 AM
  #1306
Invest2m4's Avatar
^^^agree. Rear is the same. If doing it on the ground, I use a floor jack under the diff to move the housing and line it up. Obviously, you need to be much more careful with coils in, but usually they are out if you are installing an entire kit.
Old 05-27-2014, 09:03 AM
  #1307
n3tfury's Avatar
Man, those standards look really good. I'd love some slabs too at some point. I put the extended lines on the front this weekend just to get them on and put the extended brackets on the rear. I don't have a spongy feel at all and did a real test the yesterday coming off of a 9000 foot mountain for 24 miles.
I put my LOD bumper on this weekend as well.
Name:	Mt Lemmon.jpg
  #1308
Bypass's Avatar
Yep. Jack works great.
I don't understand why anyone wouldn't do it with the tires on the ground. It's way easier and WAY safer than jack stands.
Old 05-27-2014, 09:08 AM
  #1309
Invest2m4's Avatar
Oh, gotcha. I may have misread what you said. Yes, if not using an auto-lift, I keep the tires on and do it on the ground. Using jack stands under the axle or frame is not a safe approach. By keeping the driveshaft connected and using a floor jack, I'll still do two arms at once. If the drive shaft is off, then one at a time since there is nothing to stop the axle from rotating.
Old 05-27-2014, 10:54 AM
  #1310
Space Monkey's Avatar
I've done several lifts and i always put the jeep up on jack stands. Its not unsafe if you have the right jack stands. I always do the front first then move to the rear. Never an issue.
Quick Reply: Metalcloak Thread
