Metalcloak Thread
Old 05-20-2014, 05:06 AM
  #1271
n3tfury's Avatar
Originally Posted by afletche
i'm putting a 3.5 game changer ARB edition into my 2013 JKU and can't get the rear springs in. i'm drooped as far as i can and tipped the axle to one side and i'm still a couple inches off - looks like I'm limited by the arms/geometry and the e-brake cables(?). i've got the control arms on but haven't hooked up sway bar connectors, track bar or added rear shocks yet. any trick (other than getting a spring compressor)? i figure if i unbolt the control arms i can probably flex it more to get them in but then probably won't be able to get the arms bolted in. thanks, alan
Local parts shops let you borrow spring compressors with a deposit. That's how I got mine in.
Old 05-20-2014, 08:52 AM
  #1272
snags922's Avatar
I ordered my 2.5 GC ARB yesterday. Now I am getting all my resources together. I thought I saw somewhere in this thread where someone posted all the torque values for the various bolts in the MC lift install. Has anyone else seen that? If not, does anyone know where I can look those values up?
Old 05-20-2014, 09:00 AM
  #1273
K9wells's Avatar
Old 05-20-2014, 09:03 AM
  #1274
dalearyous's Avatar
thats not readable
Old 05-20-2014, 09:04 AM
  #1275
Invest2m4's Avatar
Same values as stock. All control arms (except front uppers) are 125. Front uppers 75. Track bars 125. Lower shock bolts 56, rear upper 37. Front upper are impossible to get a torque on, but tight and start to squish the bushings.
Old 05-20-2014, 09:06 AM
  #1276
K9wells's Avatar
Maybe this is clearer
Old 05-20-2014, 09:18 AM
  #1277
snags922's Avatar
Guys, Thanks for the responses. That is great.
Old 05-20-2014, 02:48 PM
  #1278
afletche's Avatar
thanks for the input on getting the springs in. I managed to get them in by unbolting the arms and drooping/tilting all the way. Now it was no fun getting the arms back in once the springs were in but I'm just about done. Can't get the rear track bar in yet but Im assuming that once I get it back on it's wheels I'll be able to either rock it or ratchet strap the body against the frame... Fingers crossed.
Old 05-20-2014, 03:08 PM
  #1279
kjeeper10's Avatar
5 ft crow bar from HF makes quick work of coils
Old 05-20-2014, 07:25 PM
  #1280
Zroe's Avatar
Once the Jeep is back on the ground, you can push the body with 1 finger and line up the trackbars
Quick Reply: Metalcloak Thread
