Metalcloak Thread
Old 05-19-2014, 07:01 AM
  #1261
ezlifestyle's Avatar
Originally Posted by dalearyous
can anyone comment on the time between ordering your lift and having it shipped? i know it takes a while, just curious. i ordered lift and bumpers on the 8th from MC.
Took a little over 3 weeks for my lift to be delivered, and every day drags until its on your doorstep. I ordered rocker guards on the the 5th and I still haven't seen or heard from them.
Old 05-19-2014, 07:10 AM
  #1262
snags922's Avatar
Originally Posted by Invest2m4
Not exactly true. I run a GC with 6Paks and an aftermarket driveshaft. Does the shaft touch the crossover at full droop? Yes. Is that an issue? Very unlikely. Unless you are racing in the desert, both front wheels will not fully droop at the same time. With one stuffed, there is lots of clearance. I'd say the ideal solution is an aftermarket shaft and a limit strap.
I assume that anyone spending the cash on a MC (or comparable) lift, is planning to run their Jeep off-road on moderate to hard trails. The big box exhaust solutions seem like a bad idea. They all push the crossover below the frame crossmember. That means any aftermarket skid that bolts to the crossmember, won't fit. If you don't have a skid there, kiss your exhaust goodbye. Also, the bolt on products are begging for an exhaust leak.
In my view, if you want to fix the exhaust, find a good muffler shop. If you climb under your Jeep you can see how easy it would be to weld in a couple 2" sections that would push the crossover back, but not down. Can likely be done for the same price as spacers.
Ok, I'm going to wait until the factory driveshaft fails to replace that and I ruled out the exhaust spacer since I will be adding skids. That leaves limiting straps. But is this a REAL issue? Does it only rub on the driveshaft when both wheels are at full droop like Invest2m4 states? Getting in situations where I get both front wheels off the ground...I don't really see that happening. So are limiting straps even necessary?
Old 05-19-2014, 07:14 AM
  #1263
D3ADLY's Avatar
I believe mine shipped out in either 5 or 6 weeks. Then add a week for ground shipping. Took forever. That was in December/January though.
Sent from my Go Go Gadget handheld device.
Old 05-19-2014, 08:17 AM
  #1264
Jade_Monkey07's Avatar
Just got mine last week it was ordered at the end of march. And that was shipped up to canuckistan
I dont always drive where others cant. but when I do, its in my Jeep. Stay muddy my friends
Old 05-19-2014, 12:17 PM
  #1265
4x4chick's Avatar
Just a FYI. Our front drive shaft started the spit out grease on this last weekends ride. We have 29000 miles on our 2012 2 door auto Rubicon and 23000 of those miles on the current 2,5" Teraflex BB with stock shocks and shock extensions. The drive shaft has about 0.75" clearance at full droop on the driver side but do contact the exhaust when both front wheels are of the ground. On a lift, not a trail.
The Metalcloak Game changer lift was ordered last monday with 2 new aftermarket drive shafts, so our timing couldn't have been better. Hope this helps you.
Old 05-19-2014, 05:57 PM
  #1266
Zroe's Avatar
Default Superlift in Arkansas
Short vid of my Metalcloak Gamechanger 3.5 at Superlift ORV in Hot Springs, AR
Link goes to my Dropbox. If anyone knows howto embed the vid, send me a PM. The normal html ways don't work. Thanks.
https://db.tt/F99e9JWR
Old 05-19-2014, 07:58 PM
  #1267
afletche's Avatar
Default help with rear springs
i'm putting a 3.5 game changer ARB edition into my 2013 JKU and can't get the rear springs in. i'm drooped as far as i can and tipped the axle to one side and i'm still a couple inches off - looks like I'm limited by the arms/geometry and the e-brake cables(?). i've got the control arms on but haven't hooked up sway bar connectors, track bar or added rear shocks yet. any trick (other than getting a spring compressor)? i figure if i unbolt the control arms i can probably flex it more to get them in but then probably won't be able to get the arms bolted in. thanks, alan
Old 05-19-2014, 08:47 PM
  #1268
mattgt5's Avatar
Unbolt the arms and take the e brake cables off their clips. That should give you plenty of droop to get them in. Use a pry bar if you need to. Once they are in you should be able to jack up the axle and compress the springs to hook the arms up. Have you disconnected your brake lines? Be careful not to stress those if they are connected.
sent from my work leash
Old 05-19-2014, 09:59 PM
  #1269
TJM12's Avatar
I would just use the spring compressor, they are relatively inexpensive and make life easier for sure. You just need to be careful handling the spring when compressed. I've had to use that method several times before because i have tall Springs.
Old 05-20-2014, 03:07 AM
  #1270
Invest2m4's Avatar
If you have the whole axle drooped, it may be your driveshaft limiting it.
Quick Reply: Metalcloak Thread
