Metalcloak Thread
#1241
Upper fronts stay the same (18.75 I think). Adjust lowers for 5* of caster (get an alignment and have them dial it in, but you can get close). Rears depend on a lot. 2 door or 4 door, how much lift you get, and what driveshaft you're running. MC specs are for an aftermarket driveshaft and rotate the pinion up. You don't want to do that with a stock drive shaft. Assuming you have a stock shaft, measure the pinion angle before starting and target to be close to slightly higher when done. Lengthen rear lowers about 1/8" shorter than the MC specs and then dial in the uppers to get the pinion angle.
Rears I would cycle the suspension with the lowers in alone and get the bump stop to hit the pad dead center. I Agree, using the stock shaft. Too much pinion angle can cause other issues. (pinion raises with lift but will rotate down with lengthened lowers)
Dial in close to stock if needed using uppers -after lowers are set.
#1242
Anyone had a squeak? Wife complained of a squeak and it's coming from the front when the suspension cycles up and down. Tried to pinpoint it last night when moving the front manually but still not sure what is making it.
#1244
I know that the my sway bar was rubbing the front frame tube. The MC design results in the sway bar being angled up. The sway bar is never perfectly centered. I just took a grinder to the frame tube.
#1245
Getting my JKUR ready for a trip to CO and UT. I'm ordering the MC Game Changer ARB edition and Rockhard skid plates - oil pan, trans & cat conv skid; gas tank skid and transfer case skid. The gas tank skid looks like it might get in the way of the lift install. My question - is there any reason to install one of them first? Should I install the lift first, then the skids? Or doesn't it matter?
#1246
Time will tell! You'll most likely need the dealer to bleed the lines. There is a starscan tool that cycles all of abs while bleeding the lines. Some guys say to just go lock your brakes on a dirt road, but I've heard success is limited.
Try a normal bleeding and maybe you'll get lucky. If not, cough it up at the dealer. There's a handful of stories about people who couldn't get the brakes firm again....
#1247
I'm gonna try to install my MC aluminum inner front fenders this weekend. We'll see. I need to grind the part that bolts into the gap of the fender (the 3rd - back piece) because the tube they sent me is too wide. If me and a friend can't get that to work then I'll probably just Jerry-rig it to work hahaha I have the stock fenders that are trimmed and don't plan on getting the nice MC fenders (though I wish I could afford them!) so that'd be okay with me.
I'll let y'all know how it goes.
#1248
2. Install lift
3. Install new skids
Not that it will matter much, since nothing should prevent you from installing, but just in case... and it will be less stuff to possible bang your head on while installing the lift.
#1249
Is there any reason besides extra articulation to get 6pak shocks they are real neat and good tech but I'm not a rock guy
Do they do anything for high speed off road or anything like that?? Thx for replies in advance
#1250
The 6 paks will give a better on road ride but the extra articulation was the selling point for me. The high speed offroad should be a lot better than a standard shock given it's design but I have personally not ran them in that manner.
sent from my work leash
