Metalcloak Thread
Old 05-13-2014, 11:29 AM
  #1231
kjeeper10's Avatar
Default Metalcloak Thread
Lol... No. There's no fluid leaking.
Although .. I was afraid to open the res thinking that would empty the system.
Old 05-13-2014, 11:47 AM
  #1232
Space Monkey's Avatar
You'd be correct. The cap is keeping it pressurized so it only leaks very slowly. I would plug the hardlines with something just to make sure you dont run out of fluids.
Old 05-13-2014, 11:52 AM
  #1233
kjeeper10's Avatar
Ty guys. She'll be fished shortly.
Old 05-13-2014, 01:16 PM
  #1234
Rob50lx's Avatar
Originally Posted by aaronstephen
Using that shock relocation bracket, do you have any clearances issues with the frame side track bar mount hitting the shock body and full stuff?
Sent from my iPad using Tapatalk HD
No I didn't have any clearance issues.
Sent from my d2lte using Tapatalk
Old 05-13-2014, 01:19 PM
  #1235
aaronstephen's Avatar
how much bumpstop were you using?
Old 05-13-2014, 01:24 PM
  #1236
MotoJeeper's Avatar
I got a 2.5'' kit with the ARB shocks coming on Wednesday. The instructions say the control arms and track bars are set from the factory for a 3.5'' but they don't say how long they're supposed to be for the smaller lift. Does anyone know about what length they are for the 2.5''?
Old 05-13-2014, 01:26 PM
  #1237
Jade_Monkey07's Avatar
New toys are in
I dont always drive where others cant. but when I do, its in my Jeep. Stay muddy my friends
Old 05-13-2014, 01:34 PM
  #1238
Invest2m4's Avatar
Upper fronts stay the same (18.75 I think). Adjust lowers for 5* of caster (get an alignment and have them dial it in, but you can get close). Rears depend on a lot. 2 door or 4 door, how much lift you get, and what driveshaft you're running. MC specs are for an aftermarket driveshaft and rotate the pinion up. You don't want to do that with a stock drive shaft. Assuming you have a stock shaft, measure the pinion angle before starting and target to be close to slightly higher when done. Lengthen rear lowers about 1/8" shorter than the MC specs and then dial in the uppers to get the pinion angle.
Old 05-13-2014, 01:59 PM
  #1239
Rob50lx's Avatar
I was using 3/4" bumpstops and was able to cycle the suspension enough to collapse the stock shock to 15" in the new lower shock mount.
I called MC yesterday and they told me that I won't be able to cycle the suspension that much with the springs installed because the 2.5" spring will become fully compressed at about 7". That is why MC states that 2" bumpstops are required.
The 2" bumpstops should also keep the older 6" tall rear track bar bracket from contacting the crossmember/coil bucket area.
Old 05-13-2014, 02:01 PM
  #1240
gotcha. I will be using about 2" of bumpstop so looks like I should be safe on either side. thanks
Quick Reply: Metalcloak Thread
