Metalcloak Thread
Old 05-08-2014, 03:04 AM
  #1151
RocketLab's Avatar
Installed the 3.5 Dualrate ARB this past weekend with exhaust spacers spacers. DS still looks close. Ride is firmer, playing with tire pressures. Corners flat. Steering feels a little disconnected. More play at high speeds. Alignment done caster within specs but strangely camber is off. Ball joint? With only 8k miles.
Old 05-08-2014, 03:47 AM
  #1152
sea bass's Avatar
Originally Posted by RocketLab
Installed the 3.5 Dualrate ARB this past weekend with exhaust spacers spacers. DS still looks close. Ride is firmer, playing with tire pressures. Corners flat. Steering feels a little disconnected. More play at high speeds. Alignment done caster within specs but strangely camber is off. Ball joint? With only 8k miles. <img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=551285"/> <img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=551285"/> <img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=551286"/> <img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=551287"/>
What size tires are you running? Looks great!
Old 05-08-2014, 04:10 AM
  #1153
dalearyous's Avatar
i am placing my order with matson today. i will ask him about the spacer issue. i was on the fence about either 2.5 or 3.5 for my JKUR. i ultimately decided on the 3.5 because the rig will only get heavier and i never wheel with nothing in the jeep. usually carrying decent load like cooler, tools, maybe a part or two, air, sometimes some camping equipment, and other various odds and ends. all that adds up and i think 2.5" of actual lift on JKU is the bare minimum IMO. and if you are worried about center of gravity, im getting MC's rear bumper/tire carrier which drops the spare (over 100lbs) much lower than most others.
Old 05-08-2014, 05:50 AM
  #1154
Invest2m4's Avatar
[QUOTE=RocketLab;3906308]Installed the 3.5 Dualrate ARB this past weekend with exhaust spacers spacers. DS still looks close. Ride is firmer, playing with tire pressures. Corners flat. Steering feels a little disconnected. More play at high speeds. Alignment done caster within specs but strangely camber is off. Ball joint? With only 8k miles.
It is not uncommon for a lift to reveal underlying issues. What is your caster and toe-in? Many people find a little more toe-in fixes the steering feel. I had the same issue and added a little more toe and that fixed it.
Old 05-08-2014, 06:04 AM
  #1155
Invest2m4's Avatar
Originally Posted by 4x4chick
With the 2,5" lift we scrape over the rocks in SoCal a lot and I am tired of scraping. That is why we want 3,5" of lift. Might go up to 37" tires when this set is done. The price for the 2,5" and 3,5" is the same, so why not.
I guess the "why not" is because 4" of lift on a 2 door results in a fairly high center of gravity, which is not ideal in the rocks. More lift won't help dragging axles and suspension either. Also, fixing suspension geometry on a 2 door with that much lift is challenging unless you run aftermarket axles (or cut and rotate most of the brackets). With a little less that 3" in the rear, I've had hard time getting things to work. At the very least, cut and rotate the spring perches or you can shoot an arrow with the bow in the coils. Running an aftermarket rear drive shaft will require enough axle rotation that all the brackets will need to be cut and rotated. Lastly, getting enough caster will be tough for good on-road driving.
The lift cost might be the same, but the formula of $1000 per inch of lift is still in effect.
Old 05-08-2014, 06:07 AM
  #1156
snags922's Avatar
I see a lot of people calling to order with Matson. Why is that? Do they give forum members a discount or something?
Old 05-08-2014, 06:13 AM
  #1157
dalearyous's Avatar
no its just who i have been in contact with there.
Old 05-08-2014, 11:04 AM
  #1158
dalearyous's Avatar
so what has everyone here used?
spacers?
afe crossover pipe?
magnaflow crossover pipe?
Old 05-08-2014, 11:22 AM
  #1159
mattgt5's Avatar
I used an Adams 1310 with my 3.5" gamechanger. It contacted once or twice, but no issues with it.
sent from my work leash
Old 05-08-2014, 11:23 AM
  #1160
K9wells's Avatar
so what has everyone here used? spacers? afe crossover pipe? magnaflow crossover pipe?
I run stock no issues why replace it if it does need it or require it?
Quick Reply: Metalcloak Thread
