Metalcloak Thread
#1071
Finally did some flex testing to check bump stops and rub points. I got cut short on travel when we found some additional rear trimming is needed. The front is giving it all she can. In fact, I need about an additional 1/2" of bump. The rear still has about 3" of travel left once we finish the trim job.
I currently have 2" bump bump stops front and rear. I can't decide if I'm going to turn down one of the 1" stops for the 1/2" that I need in the front or just run 3" stops and call it a day. I think the rear will be good once I do a little more trimming...
I have a wheeling trip planned in two weeks so the real test is coming soon!
#1072
#1073
Has anyone notice their MC suspension squeaking? I retorqued all control arms but still have some squeaking when going over objects or pulling into my driveway.
My thinking is the 125 lb-ft of torque is enough to keep the center of the duroflex bushing stationary and not move against the control arm mounts. It could be the shocks as I still need to get under there while someone is moving the front of the JK up and down.
Thoughts?
Thoughts?
#1074
What the word on squeaking? I have not had much time with mine, 2.5", front LCA's, front track bar, rear bracket, OME shocks, but have played around a little disconnected and it definetly seems to squeak more while flexing around compared to stock. Same for everyone? I might loosen everything up, and re-torque to see if it makes a difference. I know the rear coils are bowed quite a bit, and the rear passenger does not want to seat great at the top. The basic correction wedges best (easiest) option for this? Or do not worry about it?
Another question, I have done some flexing on rocks on my property to try and check clearances, bumps, etc, but it is not very scientific. Is there a more controlled way to flex everything out to check these things?
Can't wait for the summer wheeling season to get going!
Thanks
Thanks
I emailed MC and haven't gotten a reply yet. I was going to spary some silicone on each control arm mount to see if that fixed it to give me an idea of where it is coming from.
#1075
out of curiosity how high were you able to lift the front/rear tiers before a tire comes up? You have the 12" travel? Just curious id also love to know the 2 doors.
#1076
Unfortunately I didn't measure that... I wasn't able to fully flex yet. The rub I had in the rear would've cut the tires. In the one shot I have from the back with my youngest in the picture you can see that I still have a bunch of up travel left in the rear to use. Once I get the trimming done I will check again and measure.
#1078
The Front has 11.56" of travel and the rear has 11.3". Keep in mind that my ultimate goal is to move the rear lower shock mounting locations up 1.5" to remove some of the material under the LCAs. I just haven't gotten that far yet. I like to take baby steps so troubleshooting any issues is easier. If I change too much at once it can be more difficult.
#1079
Thoughts?
Thoughts?
The only other noise that concerned me was a popping at an assumed full flex on the trail - I figured this was the coil seating itself in the base.
