Metalcloak Thread
Old 03-25-2014, 07:09 AM
  #1001
DallasJKU's Avatar
Originally Posted by jnabird333
They are working on a 1" lower rear bracket for the 2.5" kits, but my opinion is that is still too tall. At the moment, all kits ship with the tall rear bracket. I have not done a d-link flip and front track bar raise and don't plan to... The front end still does just fine and an adjustable front track bar will let you recenter the axle. Since you have a 3.6L you WILL need a new front shaft in short order, even with the 2.5" kit so plan on it.
I'm still trying to decide on a 3.5" or 2.5". I currently have 2.5" AEV and would like the extra lift, but not if it is going to need all kinds of steering corrections. I don't mind going for a new DS, but I need to draw the line somewhere with regards to price. I trust MC and their engineering, but there is so much info and misinformation out there that it gets confusing.
Old 03-25-2014, 07:15 AM
  #1002
TheDirtman's Avatar
Your just throwing money away switching from one lift to another anyway. Your money do what you want. If you want the 3.5" coils order them up and if you don't like the steering feel just swap them out for the 2.5" coils and sell the 3.5". Whats another $150-200 when you are throwing away $2k
Old 03-25-2014, 07:23 AM
  #1003
TJM12's Avatar
Actually new drive shafts will cost you much more that most steering correction stuff. I did a synergy draglink flip, not only is it very beefy but it fixed my bump steer and flighty feel. It was only $325
Old 03-25-2014, 07:27 AM
  #1004
jnabird333's Avatar
I am an engineer and I can tell you that even the best planning doesn't always work in the real world. I know for a fact that MC put a lot of effort and engineering into their kits and the rear track bar bracket, but I can also tell you that it caused more problems for me than good when put into real use.
As far as the front geometry correction goes, I think money is better spent on bracing the sector shaft brace of the steering box than a d-link flip. But that's just me and my opinion. If I had a 2-door I might think differently but I would likely test first and just budget for the possible need or want to add it if I were unhappy.
All this said, I agree with Dirtman.... It seems silly to switch "kits" for a little more lift, but it's your money and if it makes you happy, well, that's what it's all about.
Old 03-25-2014, 07:28 AM
  #1005
BatJeep09's Avatar
Originally Posted by TheDirtman
I cant tell if it were fatigue or if it was a catastrophic failure, I was not doing anything hard when it happened. Here are a couple more shots of the joint. <img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=540056"/><img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=540057"/>
My question (I haven't read the entire thread yet) did MC warranty it, or did you have to pay for a replacement?
Old 03-25-2014, 07:30 AM
  #1006
DallasJKU's Avatar
As far as the front geometry correction goes, I think money is better spent on bracing the sector shaft brace of the steering box than a d-link flip. But that's just me.... and my opinion. If I had a 2-door I might think differently but I would likely test first and just budget for the possible need or want to add it if I were unhappy.
I'm not just switching for a little more lift. I want the CA's and TB's so I can dial everything in better. It also will allow for more flex when needed. My AEV is a very generic kit and can't accomplish those goals. If it rides better and I have no doubt it probably will then it will be money well spent for me.
Old 03-25-2014, 07:32 AM
  #1007
DallasJKU's Avatar
What MC kit are you running??
Old 03-25-2014, 07:55 AM
  #1008
TJM12's Avatar
Im not running a full kit. I have all the front and rear, upper and lower duraflex control arms. I have rancho and synergy components too. Kind of a frankenlift at the moment. I doubt I'll change much more with my suspensiom, it rides great and flexes awesome.
Old 03-25-2014, 08:08 AM
  #1009
DallasJKU's Avatar
I probably could have just changed the CA's and TB's and left my AEV springs and shocks, but I really wanted the kit to be complete with their shock and coil combo. I know it is a waste of money probably, but not if it yields the ride quality I want.
Old 03-25-2014, 08:42 AM
  #1010
BuckLisa's Avatar
Going from stock arms to MC arms is not going to improve your ride much at all. It will only give you more flex off-road. There are no complete lifts. I added Rick Krawler arms to my AEV 4.5 lift and there was no need to change everything else. All for one inch... It's Your $, good luck!
Quick Reply: Metalcloak Thread
