MetalCloak Game Changer 6Pak
Old 01-31-2014 | 12:17 PM
  #61
scubaskier's Avatar
Originally Posted by PhxRainey
Most kits ASSUME that there is going to be heavy stuff loaded on the front of your jeep (Read Bumper, Winch ETC here) what you will see is a level to almost a slight UP front end if you do the lift first. But there is no science here. many times you just have to put the lift on and see how she looks. At that point you can make minor corrections with pucks.
Yeah I know that's probably going to be the case. I kind of resigned myself to that a few weeks ago. Its just I have received conflicting info and a couple of pics of actual completed jobs. Some have said it still carries a rake and some have said theirs is level. I was just trying to determine a definitive answer and try to do it once. May not be able to and have to go back and do the pucks after the fact but anyone who has a good picture of it would be appreciated.
Old 01-31-2014 | 01:04 PM
  #62
mattgt5's Avatar
Originally Posted by HardRooster
I'm fully aware of everything the Metal Cloak system has to offer. I've researched it, other lifts, custom suspension and compiled that with my experience wheeling in rigs that aren't Jeeps. I have no purchase to defend, I'm still on the stock suspension. I took my stock Rubicon on the Rubicon with another group of JK's I met on this forum. My stocker went everywhere they did, but was about half as capable as my old K5 on leaf springs. I'm looking at this from outside of the JK box. While I admire the engineering of the 6-PAC shocks, I can't justify the expense. Wheel long enough, with enough people with shocks that bolt below the axle center line and you'll occasionally break shocks. It makes sense to me that you want to run fairly inexpensive stuff if it's going to hang that low and be susceptible to trail damage. I guess if you don't see rocks it wouldn't be a problem. I only wheel in rocks, so I have a bias perspective. Also, it's a rather complex unit. I'm being speculative, but usually complex things have more problems than simple things. Each 6-PAC is like 4 shocks in one. It's also not a reservoir shock, so fade would be a concern of mine as well, if you run them fast anyway. My biggest concern with Metal Cloak, at this time, is long reported turn around times. It takes at least a month in most cases for them to fill an order. I'd be worried I wreck a shock, spend $75 plus shipping to send it in and be without a shock for a month. All in all, that's an expensive gamble, and I'm not the gambling type. The max I could justify spending on a bot on kit is in the $1,500 range. Not because it's a fixed dollar amount, but because it is about all you need to get the JK to around 90% of its capability on stock mount locations. I don't think squeezing the extra little bit of travel the six pack game changer kit offers is worth the extra $2,500. I had 16" travel shocks on my K5 with leaf springs and I made use of all of it. It's an economies of scale thing. For that extra $2,500 you can put that money elsewhere and increase your capability further, such as larger tires.
All of this is a legitimate opinion on how you would spend your cash. I have no fault in your logic for your money. But let me correct a couple of things. The six paks mount above the axle in the rear. They cut the stock location bracket off and move it up out of harms way. Agree, wouldn't want that pot of gold handing down to bash. Secondly, a stock jk shock will replace the rear should one need to come out for service. You won't have the travel of course but that is their answer to your down time question. A standard 4" lift shock fits the front, or just move a rear to the front and use the stock in the rear. As for the higher tech costing more to maintain, I would agree but am willing to pay that price for better performance. On the last point, the money could be better spent on other things such as tires, etc. I agree with you if you are on a build budget. I was not and therefore bought the best system (in my opinion) short of coil overs. I do not see the 6 paks on anyone's list who is on a budget. The sticker shock alone would eliminate them I would think.
sent from my work leash
Old 01-31-2014 | 03:16 PM
  #63
KurtieR's Avatar
Originally Posted by TH3APPL3GUY
I have the metalcloak gamechanger lite on my JK. I am really happy with how it performs both on, and offroad.
Looks like she's working great man!
Old 01-31-2014 | 03:17 PM
  #64
scubaskier's Avatar
Originally Posted by mattgt5
Glad I could help you out. According to MC they intend to leave a .5" rake when their kit is installed. My picture is a little deceiving as it is uphill. I am level with the ace carrier and the heavy spare. I think that if you put a 1/4" more in the front than east you would level out but not more than that. Mine looks flat right now with no winch.
Matt, thanks again. That's good to know and is kind of in the range I was thinking. I think I'll do the synergy 3/4" rear spacers and the teraflex 1" fronts. Should level it out I believe from what your reporting. If it end up shy of level I don't think it'll be enough to really notice.
Old 01-31-2014 | 04:19 PM
  #65
mattgt5's Avatar
Sounds like a plan.
Old 01-31-2014 | 05:50 PM
  #66
HardRooster's Avatar
The rear shock absolutely is not above the axle, or out of harms way. And it's so much larger, the chance you'll damage it is higher than with a standard, smaller shock.
http://www.flickr.com/photos/72867051@N00/12244444816/
Obviously everyone can do what they want with their money. Doesn't mean it's ever going to stop me from trying to talk people out of wasting scratch.
Old 01-31-2014 | 07:08 PM
  #67
Invest2m4's Avatar
The rear shock absolutely is not above the axle, or out of harms way. And it's so much larger, the chance you'll damage it is higher than with a standard, smaller shock. Obviously everyone can do what they want with their money. Doesn't mean it's ever going to stop me from trying to talk people out of wasting scratch.
No shock could be mounted higher on a JK without losing travel or requiring a much higher center of gravity. Of course, unless you go full fab coilovers that mount up through the tub. But now you're talking mega scratch....
13.5" of usable travel on 2.5" of lift, in my view, is pretty solid. Not to mention doing it with 37s. Though, I have a 2-door and am therefore much more sensitive to keeping my Jeep near the ground.
Old 01-31-2014 | 07:31 PM
  #68
mattgt5's Avatar
Sorry, above the axle is not correct. The mount is moved on the side of the bracket behind the hub. Instead of hanging down below the reinforced bracket it is on the back side. To me that greatly reduces the risk of damage and increases ground clearance.
  #69
I know, that wasn't really my point. My point is shock damage for shocks mounted below the axle centerline is somewhat inevitable (on a long enough timeline) so how expensive do you want those damaged shocks to be?
You can buy brackets (Synergy) that will move your rear shock mount up 2". You can do hoops in the front as well. You can also, if desired, move the rear shock brackets up (Evo) just like the game changer bracket. This would give you the opportunity to run a longer travel shock. Not as long as the 6 PAC but close enough to not matter since the Jeep itself, more so than the shocks, is the primary limiting factor in suspension travel, which is why the GC still comes with bump stops.
Old 02-02-2014 | 03:06 PM
  #70
GJeep's Avatar
I don't have the MC and had never driven a Jeep with it.
However, because of the quoted feedback, and many similar ones, plus the videos which show how this suspension behaves, I'd have ordered it right now, if I could have MC service in my country.
A question to those who have the MC --
I wonder if the dual rate MC coils alone, without the 6-Paks, but with properly re-valved Fox shocks, would improve on & off road ride, vs my Full Traction coils ?
It's not that the Full Traction lift is bad. It works very well, and is relatively soft (compared to lifts I tried on others' Jeeps).
I'd move over to MC coils, if I can get overall softer ride, enough of an improvement to justify the change.
I know it's not simple to reply this, but that's my only way to gain some info...
Thanks
Quick Reply: MetalCloak Game Changer 6Pak
