Metalcloak 3.5 lift 2d no drive shaft needed?
I keep reading tread after tread on this and other sites but can't find any reviews about the Metalcloak that are not 100% positive. I feel like there has to be something out there negative as nothing is that good? I have the 2d 13 JKR. I was told this set up only needs the exhaust spacer and was designed for stock drive shafts. My drive shaft will clear the cross member with the spacers but will I need a drive shaft anyway because of the angle sooner than later? 2013 model 2 door.
With a 3.5" lift and only a MK front bumper with a winch is this going to give me more than 3.5" on a 2d? The springs are suppose to be dual rate.
The MK is suppose to be designed for on road handling and max articulation. Are these two designs normally opposite from each other?
Thanks
Thanks
Well kind of... I would budge for an exhaust spacer and driveshaft. One of my local trail buddies has a JKR and he still rubs his boot on a 3inch lift and he has an exhaust spacer. He does run 35s with cut fenders and stock bumpstops. When we wheel he always takes his whole front sway bar out.... Also what tire size are you thinking of going to. You could do a 2.5 inch lift, exhaust spacer, cut fenders or flat fenders and 35s.
