MBRP to DYNOMAX exhaust
Old 09-30-2015 | 07:56 PM
horrocks007's Avatar
Default MBRP to DYNOMAX exhaust
I am replacing my MBRP exhaust that has rusted through for a second time with a dynomax super turbo axle back system, only problem, the tubing is different.
The angle for where the exhaust connects is completely different.
Anyone else run into this problem?? Solutions?
Is there a dynomax rep here that can help?
I'd like to do the install myself, not wanting to spend a lot of cash on this.
Thanks for help.
Old 10-01-2015 | 11:03 AM
Invest2m4's Avatar
I'm not sure I understand the issue? Did you cut something off for the last exhaust? Make sure you are looking at the correct part for your model year. The Dynomax should be bolt on. The design for the 3.8L will be different than the 3.6L. Did you maybe remove more of the stock exhaust for your last system? Basically, are you trying to bolt dynomax onto part of an MBRP system?
Old 10-01-2015 | 02:47 PM
Ilikedirt2011's Avatar
Pics might help
Old 10-01-2015 | 08:17 PM
thzpcs's Avatar
Are you sure you have the right exhaust system to begin with?
Old 10-02-2015 | 09:47 AM
Yes, I'm trying to bolt the dynomax onto the MBRP system since I no longer have stock exhaust piping.
Turns out I'm taking it in to have pipes fabricated.
Quick Reply: MBRP to DYNOMAX exhaust
