maybe a dumb question
That is not a dump question at all. Currently - no. But I am sure there will eventually be options for that. When Jeep offered the Rubicon transfer case manufactures seemed to stop offering re-gearing kits. They were available for ealier years pre-Rubicon.
Best current solution: Get a Rubicon Case, or go big with at Atlas.
You can get an aftermarket case like an Atlas that CAN be regeared. BUt as stated, as of now, not the stocker. You can get a case from a Rubi and it will be different than an X or Sahara. I think the Rubi is like 4 to 1 and the others are 2.7 to 1 or somethin like that....I forget.
Yes and no. If you mainly wheel in sand, mud, fire roads or blasting around the 2.7:1 X case is better.
If you like to crawl on rocks and do technical stuff that could put you on your roof easy then the Rubicon 4:1 is better.
I blasted the sand dunes at Pismo Beach with my X case, spend a lot of time doing hill climbs in 3rd gear, 4 low. I guess with the Rubicon case it would have been 5th.
