May be really screwed.
So I am installing the evo flip kit and I didn't not receive the crush sleeve for the newly drilled hole on the knuckle. What are my options. I can not wait for a new sleeve from evo.
I am going to be honest I think you are out of luck next time check for all parts before starting. I did a quick search and have no idea where to get one really fast there is no way your local hardware store has one.
I have the teraflex flip kit, the installer did not use the crush sleeve. He carefully used a conical drill tap on the link mount. He stated the crush sleeve was weak and not needed for my application. Now, if I could only tell you where to buy that drill.
So my solution was to cut a piece of air duct tin and make my own crush sleeve. It worked like a charm. I only drilled it out to 3/4 with a step up conical bit. This will work until I can make it down and buy a sleeve from the 4 wheel parts store.
Sponsoring Manufacturer
I would say your installer is wrong but if it works fine then great!
