Major problem after tire rotation!!!
Originally Posted by JK-Ford
I rotate the tires myself on all my vehicles. Been doing it a long time. The only effects that I have noticed is "longer tire life".
Same here. Have more than one set and when exchanging them I simply rotate at the same time. Never had any problems.
There are two ways of balancing the tires, as far as I know. One is by itself (most common?) and another is assembled on the axis (not so common and I believe more suitable for high performance = speed). The second may create problems when rotating.
As an example, the set I am running now was mounted by Discount Tires and I simply took them home and mounted on my Jeep. No issues whatsoever.
yep, i changed my oil last week and was wondering about rotating tires but thought, naaa...i better not....but now, i'm for sure gonna try it out!
same with me.. never had a issue... Ive been rotating my own tires for years ... the problem is not rotating your own tires.. it is just making sure they are balanced..
Here is the link to a sponsors website with the above item: http://www.4wd.com/search.aspx?kw=Centramatic
I am curious as to how well the work.
I do a 5 tire rotation. I use this method to make sure that my spare is capable of being used as a running tire if necessary. With 4WD vehicles, and newer vehicles with TCS, you need to be careful mixing tires of different size. Even mixing a new tire with three wore out tires could cause a problem.
Edit: I have always went front to back on same side. Always got good life out of tires.
At least be aware of it.
