M.O.R.E. 1" body lift conflict with 2010 Rubi Unlimited
So I installed the M.O.R.E. 1" body lift today so I could make my rubi rails work with Shrockworks sliders (I know it's not necessary but it looks clean). On my Jeep there are only 5 mount points per side - not 6 like the WOL writeup or M.O.R.E. installation guide suggests. The one between the spring seat and the shock is not there. The rear most mount is beefed up though and uses a larger washer and bolt. So the smaller bolts and spacers with the smaller inner diameter were a no go. Had to use washers out of the bolt bucket and grind the flange and 1/8 inch off the factory bolts to make it work. Has anyone else run into this?
Not sure
I've never heard of a JK/U that didn't have 12 body lift mounts. You're MORE body lift should have come with 2 aluminum spacers and 2 bolts for those rear mounts that are larger in diameter.
Might want to look closer at the jeep and the kit?
Yeah me too. All spacers were uniform. All bolts were uniform. And the spot where the other mounts would have been were just holes in the body and frame.
Did you buy your JK used? New? If new, take it back to the dealer ASAP if these mounts are missing. If used, someone probably got to those body mounts before you did...Hell, I'd take it back new or used from whoever you bought it from if these are missing. That's BS.
As for the kit, I would call MORE and discuss your issues. There should positively be 2 spacers and bolts that are sized differently than the rest for your rear mounts.
Curious to see a pic of what it looks like. I had mine specifically made to work without a BL, but I am considering doing a BL anyways to get a little extra room for 37s. I am also looking at getting the same BL since it is on sale right now.
Since I did the picture edit below, I found out that 2008+ JKs have fewer body mounts than 2007s, and the rear most body mounts take a larger/wider bolt.
WOL's write-up is on an 07.
Here are pics of a bare frame and a pic from the M.O.R.E. install instructions (08s+ don't have #s 9 and 10):
