Lower/upper control arm lengths for 2.5" lift on a 2-door?
You may want to tack weld up your arms first them mount them. You could check your camper and pinion angle at that time. You would need a good angle finder. There are some magnetic mount readers for camber available also. Then you could weld them up and be good to go. Its alot of work! Goodluck
I have 2.5 teraflex coil and Dave from Northridge recommended to me to also get front adj trackbar and adj front lowers and I should be plenty fine. I have the lift in except the lower control arms or trackbar! It rides great with the stock 32's so far. This week I will be put on my 35 MTRs on and drive it see how it drives. Then install the lowers and front trackbar by next weekend!
I put in my trackbar this weekend and wow what a difference. My jeep must of been doglegging or something before. I should of installed the adj front trackbar a long time ago.
