Lower rear control arms
Rock Crawler Degree Wedges
Buy these from Rock Crawler or Northridge for $30. It should help. It got my springs of my stock track bar after putting control arms on and moving the axle back. Theres some threads on them.
i have noticed my rear coils bowed out a lil toward the rear on mine, what do you do to correct that? if the control arms don't push the axle back, what could be done. or is it the lower rear push out 5/8 of an inch, and the top rear pull in 1" to get it all straight?
I had that problem also when I installed my adjustables. I took and cut off the existing spring perches and put the bolt on ones on. Took care of the Bowing problem and the coils hitting the track bar.
