Lower rear control arms
Was getting ready to pull the trigger on some rear lower arms. Was curious how far far a can move the axle back with the stock drive shaft. Was thinking of currie for the arms. just didnt have enough dough to get a rear drive shaft yet and want to move the axle back an inch
JK-Forum Founder
you really can't move your axle back that much and not because of any problems that you might have with your driveshaft but rather, problems of rubbing of your coils on your track bar.
![Yup](https://www.jk-forum.com/forums/images/smilies/yup.gif)
![naw](https://www.jk-forum.com/forums/images/smilies/icon_naw.gif)
JK-Forum Founder
unfortunately, you can't extend the lengths of the lower rears more than about a 1/4" or so. regarding your pinch seam, your best bet is to do what the rest of us have done and that's to hack the end of it off at an angle.
Depending on which rear track bar your running, you can move the axle back 1/2" to 1". This will of course cause the rear springs to be bowed a lil more and you will need to address that. Im running the Tera rear bar, axle moved back around 5/8". No track bar rubbing issues.
![Thinking](https://www.jk-forum.com/forums/images/smilies/thinking.gif)
